Home > Technical > Spare wheel use
Guyzer73
Spare wheel use
This may be a stupid question, well probably is.
I've got the standard RRS spare wheel (19" 50mph max type), but, run 285/50R20s can I use this if I have a puncture, or is the diameter difference between the tyre sizes to great and I'll damage the diff?
the reason I ask is that it's getting hot here now so its time to hit the Wadi's where there's a real chance of punturing the tyres on a rock.
Or would it be safer to get 2 spare 20" rims with the same 285/50R20s one on the roof rack fully inflated, one semi inflated in lieu of the original spare?
Post #295204 Wed Apr 06 2011 1:38pm
You "might" get an HDC error running the spare but nothing more.
Also the gear change may become erratic
OK for the short term though RRS gone
Post #295220 Wed Apr 06 2011 4:42pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
remember this is a four wheel drive car not the cheaper more problematic AWD (all wheel drive) where tyre sizes are critical
Post #295221 Wed Apr 06 2011 4:48pm
Guyzer73
Cheers for the information lads, hopefully of this weekend to Jebel Shams and Jebel Aktar Smile working permitting as always.... 2006 RRS S/C CONSTANTLY under modification...
Post #295486 Sun Apr 10 2011 8:57am
tempestv8
Australia
What's up with the Range Rover Sport having a "space saver" when a Discovery 4 has a full size spare? 1999 Discovery II V8 auto
Post #304398 Wed Jun 29 2011 11:19am
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Will a 20" wheel & tire not fit underneath the car then?
FYI. AAA in Dubai have a set of 4 very good condition 20" rims and tires going for 5000Dhs. They are nice rims too...not the standard type. Tires are less then 1 year old. Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #304447 Wed Jun 29 2011 4:17pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
OMG
I would imagine that there is absolutely no way you can drive with a 19" wheel while the rest are 20". Just think about it, the revolution of the 19" is much quicker and therefore the drift would be horrible! Vadim A.
Post #304545 Thu Jun 30 2011 11:37am
flydive
Vadim,
You kidding, right? '08 RRS TDV8
Post #304549 Thu Jun 30 2011 12:25pm
Lookers Park Royal
Don't panic!!!! Most early RRS have a 19" reduced speed wheel (black) as a spare. You will find that although the wheel size is 1" different, the actual rolling radius between the two would be similar as the 20" has a lower profile tyre. Wink Thumbs Up
Having a worn tyre on one side and a new one the other (replicating what would happen if you had a puncture on a worn tyre and your spare was a new 20") would have a differnt rolling radius to the tune of 1/2" I'd say??!! Whistle
James Thumbs Up
Post #304555 Thu Jun 30 2011 1:37pm
