Home > Maintenance & Modifications > loss of power and smokey |
Either a pipe has come off or split, possibly on your turbo or maybe you have an EGR valve thats goosed, common on 2006 models
Tue Apr 05 2011 7:33pm |
S60 BOS Member Since: 05 Apr 2011 Location: Reading Posts: 5 |
thanks Ady 555 im hoping its one of the cheaper problems |
Tue Apr 05 2011 10:08pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
Hopefully just an intercooler pipe split...
Wed Apr 06 2011 10:35am |
had a look at that pipe cant see much though it due a service so might just get land rover to sort it |
Fri Apr 08 2011 11:34am |
Found out the fault code was coming up as a faulty EGR and just had both replaced and it still Smokey I’ve checked the intercooler and its pipes and there all good although did notice oil in the bottom of the intercooler pipe meaning oil in the intercooler??? is this normal after replacing a faulty EGR or do you think its a turbo problem the car has 66k on the clock are they known for turbo problems. |
Wed Apr 20 2011 10:11pm |
Could be a tubo pipe delaminating inside.
Thu Apr 21 2011 10:42am |
