![]() | Home > Maintenance & Modifications > loss of power and smokey |
Either a pipe has come off or split, possibly on your turbo or maybe you have an EGR valve thats goosed, common on 2006 models
S60 BOS Member Since: 05 Apr 2011 Location: Reading Posts: 5 ![]() ![]() ![]() |
thanks Ady 555 im hoping its one of the cheaper problems |
Hopefully just an intercooler pipe split...
had a look at that pipe cant see much though it due a service so might just get land rover to sort it |
Found out the fault code was coming up as a faulty EGR and just had both replaced and it still Smokey I’ve checked the intercooler and its pipes and there all good although did notice oil in the bottom of the intercooler pipe meaning oil in the intercooler??? is this normal after replacing a faulty EGR or do you think its a turbo problem the car has 66k on the clock are they known for turbo problems. |
Could be a tubo pipe delaminating inside.
