Home > Technical > Adaptive Cruise Control & Voice Control
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
How do you tell if your car has ACC? I have buttons on the wheel for speeding up / slowing down the car....is This ACC?
Also when using the voice control to dial numbers etc the system can understand fully what i am saying and displays teh number correctly but then at teh end when the systems prompts CONINUE no matter what i say it is wrong, any ideas?
Post #286889 Tue Jan 25 2011 4:58pm
Charlesrmh
Hi Chris,
To confirm you have AAC take a look at the air intake opening in your front bumper above the number plate. To oneside should be a black/dark grey insert that has imprinted in it AAC. That is the device that monitors the distance between your car and the vehicle infront.
You voice control requires you to tell it to "DIAL NUMBER" when you have told it the number you wish to dial.
Hope this helps.
Regards,
Charlie Charlesrmh
Post #286893 Tue Jan 25 2011 5:18pm
Bob
2006 Range Rover Sport Supercharged Zermatt Silver
Charlesrmh wrote:
Hi Chris,
Regards,
Charlie
This is correct.
Also, if your car automatically slams on the brakes whilst you are overtaking a lorry in the rain/spray, and the car behind almost shunts into you, that also means that you have ACC!
Bob.
Post #286925 Tue Jan 25 2011 10:09pm
Buster007
Bob wrote:
Charlesrmh wrote:
Hi Chris,
Regards,
Charlie
This is correct.
Bob.
Bob, Best not to use the ACC in the rain then?? Thanks for the heads up that could've just saved a life!! Have you told everybody on the forum that should be a sticky!! Cheers Laurence.
Post #286928 Tue Jan 25 2011 10:24pm
chris mc
Aha i don't have it then cause it doesnt slow down at all. Cheers guys
Just need to work out how to keep the bird in the box happy now and get her do what i want lol
Post #286930 Tue Jan 25 2011 10:34pm
Bob
Buster007 wrote:
Bob wrote:
Charlesrmh wrote:
Hi Chris,
Regards,
Charlie
This is correct.
Bob.
I hate ACC..........
As well as the above scenario..........
Imagine cruising down the road, listening to the radio minding your own business. You don't realise that the car in front of you is slowly slowing you down until you're doing 20mph less than you set your speed to, so you pull out to overtake and the gearbox drops 2 gears and accelerates hard back up to speed.......using half a gallon of petrol.
or.....
You're in the middle lane approaching a slower vehicle, you check your mirror to pull into the fast lane, and just as you pull out (it's all about the timing), the ACC sees the rear of the car you're passing and slows right down, just as you pull into the fast lane in front of another speeding car.
or,
You're moving into the fast lane between 2 cars (when there is a gap, obviously), and just as you pull out, the ACC detects the car in front, and slams the brakes on. The guy behind is almost never amused!
Bob.
Post #286931 Tue Jan 25 2011 10:36pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
If you have ACC you have two small buttons on the side of the cruise control speed settings for controlling the distance from the car in front.
Overall I love ACC, there are a couple of annoyances but as soon as I drive our other car which has standard cruise control I miss it! It's very relaxing on motorways when the road isn't clear to keep a constant speed. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #286933 Tue Jan 25 2011 10:56pm
Bobby
If you have ACC then your steering should have the additional buttons 5 & 6 ...
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #286947 Wed Jan 26 2011 12:29am
RichardM
On the 2010+ models the buttons are to the side. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #286949 Wed Jan 26 2011 12:38am
Bobby
Yes, you're right, however, chris' RRS is a MY2007 and hence the above post was specifically for his benefit. Wink Malaysia Boleh!
Post #286951 Wed Jan 26 2011 1:50am
RichardM
Ok Embarassed he didn't have anything in his profile/signature/gallery so I wasn't sure! WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #286960 Wed Jan 26 2011 7:15am
I've had to change the "following distance" to minimum... because otherwise you're always over-ruling it just to keep a constant speed
Now it's much easier, the light comes on the dash to say you're closing up on something (50m or so), but it never actually adjusts the speed (in my case anyway, as I move out to overtake in plenty of room) and it only takes over if you actually do need to slow down.
Another hint
MPG is always better on the motorway when not in cruise control, go figure Wink RRS gone
Post #286980 Wed Jan 26 2011 12:53pm
I always check the little RRS under the post count Wink Mr. Green Rolling with laughter RRS gone
Post #286981 Wed Jan 26 2011 12:57pm
chris mc
Thanks for all the info guys, i don't have it and by the looks of it i am quite glad i dont lol
Post #286987 Wed Jan 26 2011 1:51pm
Ahhh but it's great to brag about in the pub... Laughing RRS gone
Post #286997 Wed Jan 26 2011 2:59pm
