![]() | Home > Technical > Adaptive Cruise Control & Voice Control |
Charlesrmh Member Since: 28 Aug 2010 Location: Middlesex Posts: 5 ![]() ![]() |
Hi Chris,
Bob Member Since: 19 Aug 2006 Location: Pump No. 3 Usually! Posts: 49 ![]() ![]() |
This is correct. Also, if your car automatically slams on the brakes whilst you are overtaking a lorry in the rain/spray, and the car behind almost shunts into you, that also means that you have ACC! Bob. |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
Bob, Best not to use the ACC in the rain then?? Thanks for the heads up that could've just saved a life!! Have you told everybody on the forum that should be a sticky!! Cheers Laurence. |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Aha i don't have it then cause it doesnt slow down at all. Cheers guys
I hate ACC.......... As well as the above scenario.......... Imagine cruising down the road, listening to the radio minding your own business. You don't realise that the car in front of you is slowly slowing you down until you're doing 20mph less than you set your speed to, so you pull out to overtake and the gearbox drops 2 gears and accelerates hard back up to speed.......using half a gallon of petrol. or..... You're in the middle lane approaching a slower vehicle, you check your mirror to pull into the fast lane, and just as you pull out (it's all about the timing), the ACC sees the rear of the car you're passing and slows right down, just as you pull into the fast lane in front of another speeding car. or, You're moving into the fast lane between 2 cars (when there is a gap, obviously), and just as you pull out, the ACC detects the car in front, and slams the brakes on. The guy behind is almost never amused! Bob. |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
If you have ACC you have two small buttons on the side of the cruise control speed settings for controlling the distance from the car in front.
If you have ACC then your steering should have the additional buttons 5 & 6 ...
On the 2010+ models the buttons are to the side. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Yes, you're right, however, chris' RRS is a MY2007 and hence the above post was specifically for his benefit. |
Ok |
I've had to change the "following distance" to minimum... because otherwise you're always over-ruling it just to keep a constant speed
I always check the little RRS under the post count ![]() ![]() ![]() Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
Thanks for all the info guys, i don't have it and by the looks of it i am quite glad i dont lol |
Ahhh but it's great to brag about in the pub... |
