Home > Maintenance & Modifications > Key Fob case change
simonw007
United Kingdom 2005 Range Rover Sport Supercharged Zermatt Silver
Sorry, my small stock of fobs is now gone. Sad
Simon
Post #292226 Mon Mar 14 2011 12:11pm
christophebcn
Spain
no worries, it was worth a try... i'll go ahead and get one form the link you posted Thumbs Up
Post #292228 Mon Mar 14 2011 12:14pm
lionheart44
United States
quick question in regard to that link. Is that for just the fob case or does it come with the circuit board and a key blank as well? also is there serial number or a reference number? my current keys are have "ywx000071", so i would need something compatible. any help is much appreciated!
Post #293363 Wed Mar 23 2011 1:59pm
simonw007
The link I posted was just for a replacement fob case. This came with the two part plastic shell, a rubber internal buffer, the key blank, the key button, key holder, key spring and metal key ring bracket. You would need to transfer your current circuit board and possibly the key blade if you dont want to get the blank cut.
I am afraid I do not know the reference number of whether your key is compatible with the case in the link, you might need to send the supplier an email.
For pictures, you should be able to find the key fob case change instructions in my gallery.
Simon
Post #293438 Thu Mar 24 2011 9:37am
lionheart44
United States
I have some conflicting reports. Can a once programmed circuit board/transponder be "reprogrammed" to a new RR to be able to start the engine or just unlock the doors? I have been told i would need a "new, never programmed" fob to be able to start my engine, but then i have also read the used fob can be "re-programmed" for my RR and be able to unlock doors and start the engine. Can anyone shed any light on this?
Post #293481 Thu Mar 24 2011 2:24pm
lionheart44
United States
Ok, thanks again for all the help... If i buy a new fob from british parts of Utah for 155 and put the blade i have in it, is my only option to then bring all keys to a land rover dealership and have them programmed or can i program them myself or go somewhere besides a dealership to have them programmed to unlock AND start the RR?
Post #294429 Thu Mar 31 2011 12:23am
RRS PIMP
Key Fob case change
I have a couple of Key Cases left over, they have the Land Rover Logo on the 3rd button.
Post #295696 Tue Apr 12 2011 12:55am
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
What a superb write up Simonw007! Bought a new fob case online and followed your instructions, bit of a hassle taking the old fob case apart but as I wasn't trying to preserve it I just got tore into it (minding the circuit board insde of course). I didn't bother knocking the pin out of the key either, I just swapped the key from my old battered fob onto the new fob casing...works a treat and saved myself a few quid!....Thanks! Bow down Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #444681 Mon Dec 08 2014 7:03pm
