Home > Technical > Disabled question??
wasnotwas
Disabled question??
Hi iam very interested in buying a new range rover sport se i was just wondering could you tell me if there is a big difference in access height between a range rover and an mercedes ml 320 i have a bit of a problem with my legs but can manage to get in and out of the ml quite easily thanks..
Post #284889 Wed Jan 05 2011 4:50pm
Bradders
I suspect it might be easier in the RRS as it has an access height setting which drops the air suspension lower than normal by about 2-4" to get in and out. Maybe best to have a go at your nearest dealer just to be on the safe side. Best of luck. Thumbs Up
PS Ive just seen your duplicate post. Embarassed FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #284938 Thu Jan 06 2011 6:17am
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Don't forget the access mode can be programmed to the key button so if someone else drives the car and leaves it at normal height you can just put it at the right height before you get there....
Alex
Post #284957 Thu Jan 06 2011 10:35am
rrspoland
Poland 2006 Range Rover Sport Supercharged Rimini Red
isn't the access height working only while the car is on emergency lights?
As far as I know, you cannot easily change the height of the car with doors opened and without emergency lights on. This is for safety reasons. My name: Patryk
RRS 4.2 s/c Rimini Red
Post #284965 Thu Jan 06 2011 11:30am
Endjin
Scotland
Not in UK anyway. You're correct about the doors open part. If you open the door before it has finished moving it will stop. But, there is no need to have the emergency/hazard lights on. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #284978 Thu Jan 06 2011 12:43pm
can't you program the LR button on the Fob to drop to access height, but only when you have the hazard lights on at the same time, sort of to aid getting things in the boot?
Post #284980 Thu Jan 06 2011 12:50pm
BLH
The RR will lower from norm almost 2" and raise for off-road from norm a further 2"
so your looking at a 2" benefit to yourself.
Im a paraplegic and manage to climb into my RRS just fine.
tend to use the grab handle to leaver myself in.
Post #285146 Fri Jan 07 2011 4:57pm
Jonny Fresh
Yes hazard lights have to be on for keyfob button to lower it.
Post #285147 Fri Jan 07 2011 4:59pm
