Home > Technical > Disabled question?? |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
I suspect it might be easier in the RRS as it has an access height setting which drops the air suspension lower than normal by about 2-4" to get in and out. Maybe best to have a go at your nearest dealer just to be on the safe side. Best of luck.
Thu Jan 06 2011 6:17am |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 |
Don't forget the access mode can be programmed to the key button so if someone else drives the car and leaves it at normal height you can just put it at the right height before you get there....
Thu Jan 06 2011 10:35am |
rrspoland Member Since: 04 Dec 2008 Location: Warsaw Posts: 123 |
isn't the access height working only while the car is on emergency lights?
Thu Jan 06 2011 11:30am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Not in UK anyway. You're correct about the doors open part. If you open the door before it has finished moving it will stop. But, there is no need to have the emergency/hazard lights on. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Thu Jan 06 2011 12:43pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
can't you program the LR button on the Fob to drop to access height, but only when you have the hazard lights on at the same time, sort of to aid getting things in the boot? |
Thu Jan 06 2011 12:50pm |
BLH Member Since: 02 Jan 2011 Location: Newbury Posts: 14 |
The RR will lower from norm almost 2" and raise for off-road from norm a further 2"
Fri Jan 07 2011 4:57pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Yes hazard lights have to be on for keyfob button to lower it. |
Fri Jan 07 2011 4:59pm |
