Home > Technical > washer jets not working
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
hi guys,
problem with washer jets after recent cold weather, jets on headlamps are working fine but no water from bonnet jets or rear window. I suspect some connection has come loose but I cant see it when i open the bonnet does anyone have any suggestions?
Post #283048 Tue Dec 14 2010 10:33pm
Bradders
Youve got to remove the under bonnet sound proofing to get to the electrical connections and hoses for the nozzles. You have to unclip them from underneath and push them out of the bonnet.
One of mine stopped working as well recently but was easily sorted once I took it off the car and cleaned it out with a fine needle. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #283049 Tue Dec 14 2010 10:39pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
check the relay is clicking when you push the button
If you have the ignition on and push the washer button and you should hear a click from the pass side foot well and also hear the motor running under the bonnet. IF not its likely the fuse, i had a similar problem.
I replaced the std fuse last winter but it kept blowing so i stuck a slightly larger one in it a 15amp (or maybe 20amp) and its never caused a problem since
Post #283083 Wed Dec 15 2010 2:20pm
crowej
i dont think its a fuse as i am getting water out of the headlight washers
Post #283098 Wed Dec 15 2010 3:09pm
Bradders
Check the manual as they might have separate fuses. FF 4.4 V8 Soooo looking forward to this bad boy
Post #283099 Wed Dec 15 2010 3:20pm
MikeS
Australia 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
It's the fuse blown, replace it with a 20 amp one and all is fine (the fusebox is under the dash on the passenger's side and the fuse itself is a swine to get at). The headlamp washers are on a different fuse to the front & rear washers, hence the headlamp ones still working.
My RRS did exactly the same thing last winter, it's a Censored trying to wash the windscreen on the M5 with only the the overspray from the headlamp washers Laughing Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #283106 Wed Dec 15 2010 5:11pm
crowej
thanks Guys, it was the fuse
Post #283116 Wed Dec 15 2010 5:54pm
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
I have the exact same problem. Which fuse it it btw? 91 BMW 850CSI
Post #364064 Thu Nov 22 2012 3:16pm
29, engine compartment fuse box RRS gone
Post #364065 Thu Nov 22 2012 3:22pm
Fatandre
I just checked the fuse 29 (green 30) and it is ok.
Now I am confused 91 BMW 850CSI
Post #364071 Thu Nov 22 2012 3:40pm
Fatandre
On disco3 forum which are similar to the RRS they say its the fuse nr 11 behind the glove box. Any idea how to access the box and am I maybe just wrong? 91 BMW 850CSI
Post #364222 Fri Nov 23 2012 3:23pm
To access the fuse box, just carefully take the right hand side of the glove box out of the 'runner' its in. Once released, the glove box will drop down, revealing the fuse box Smile ON THE WAY: BMW F21 M140i
Post #364224 Fri Nov 23 2012 3:35pm
Fatandre
fixed 91 BMW 850CSI
Post #364228 Fri Nov 23 2012 5:08pm
Stuart
What a super resource this place is. There it was, red 10A fuse number 11 behind the fuse box. Thumbs Up Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #491544 Tue Mar 22 2016 7:20pm
fialoe
Ireland 2005 Range Rover Sport TDV6 SE Cairns Blue
Hi Guys, I am a new member and apologise for jumping in on an old thread however I felt this was the best place as you may have experience of my problem. My RRS just failed its NCT (MOT) because the headlamp washer jets dont work. They did but now dont and I am not sure how long this is the case but relatively recently. I have checked the fuses in the glove compartment and under the hood and all ok. I cannot find the relay. I removed the bumber and no sign of a blockage so it is either the relay or pump (I am aware the lights need to be on and every 3 times). Can anyone help with suggestions or location of the relay assuming there is a relay dedicated to the washer jets?
Post #532279 Tue Aug 08 2017 9:36am
