![]() | Home > Technical > washer jets not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
I thought the headlight wash relay was under the bonnet, but will have to check tonight |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 168 ![]() ![]() ![]() |
I had the exact same issue, fuses were all ok however the headlight washer pump ( which is separate )was totally seized through corrosion, replaced it and all ok.
