![]() | Home > Technical > washer jets not working |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
hi guys,
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Youve got to remove the under bonnet sound proofing to get to the electrical connections and hoses for the nozzles. You have to unclip them from underneath and push them out of the bonnet.
i dont think its a fuse as i am getting water out of the headlight washers |
Check the manual as they might have separate fuses. FF 4.4 V8 Soooo looking forward to this bad boy Ex 2006 RRS SC - garbage Ex 2016 135i M Sport - dream car Ex 2003 RS6 Avant - piece of cr*p Ex 2014 320d X Drive, M Sport Touring - ok I guess Ex 2007 RRS TDV8 - bloody loved it EX 2007 FL2 XS - not so bad |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
It's the fuse blown, replace it with a 20 amp one and all is fine (the fusebox is under the dash on the passenger's side and the fuse itself is a swine to get at). The headlamp washers are on a different fuse to the front & rear washers, hence the headlamp ones still working.
thanks Guys, it was the fuse |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
I have the exact same problem. Which fuse it it btw? 91 BMW 850CSI |
29, engine compartment fuse box RRS gone
I just checked the fuse 29 (green 30) and it is ok.
On disco3 forum which are similar to the RRS they say its the fuse nr 11 behind the glove box. Any idea how to access the box and am I maybe just wrong? 91 BMW 850CSI |
To access the fuse box, just carefully take the right hand side of the glove box out of the 'runner' its in. Once released, the glove box will drop down, revealing the fuse box |
fixed 91 BMW 850CSI |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
What a super resource this place is. There it was, red 10A fuse number 11 behind the fuse box. |
fialoe Member Since: 08 Aug 2017 Location: Dublin Posts: 1 ![]() ![]() ![]() |
Hi Guys, I am a new member and apologise for jumping in on an old thread however I felt this was the best place as you may have experience of my problem. My RRS just failed its NCT (MOT) because the headlamp washer jets dont work. They did but now dont and I am not sure how long this is the case but relatively recently. I have checked the fuses in the glove compartment and under the hood and all ok. I cannot find the relay. I removed the bumber and no sign of a blockage so it is either the relay or pump (I am aware the lights need to be on and every 3 times). Can anyone help with suggestions or location of the relay assuming there is a relay dedicated to the washer jets? |
