Home > Technical > Cold starting problem TDV8 |
Old Stager Member Since: 12 May 2010 Location: Staffordshire Posts: 120 |
Now...I've got a confession to make Having now read the manual (!) it says if the car repeatedly fails to start you should keep the start button (and brake pedal) pressed until it starts (rather than pressing and releasing the button immediately as you would with a normal start). I will try this next time I have the starting problem; hopefully it will cure it.
Sun Dec 05 2010 9:54pm |
I take it all back. -10C this moring and we're back to square one; it took about 12 attempts to start, even with finger planted on the button as per the manual. Spoken to two local dealers. Both agreed it's not right and both suggested I call Land Rover Assistance if (when!) it happens again, because by the time the dealer can have the vehicle in, the chances are the weather will be warmer and they won't be able to replicate the fault. They say it's unlikely that any fault code will be stored as a) there is no warning given on the dashboard; and b) the engine isn't starting so won't recored a fault 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Tue Dec 07 2010 3:34pm |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
Take it to the dealer get a loan car get them to leave it out in the cold and let them try it / sort it, they have more access to tek than the assist cars do surely 2014 5.0SC AB
Tue Dec 07 2010 11:26pm |
greg Member Since: 18 Jan 2010 Location: Central Scotland Posts: 9 |
New 2010 TDV8 Autobiography - refuses to start -currently -11degrees-waiting for LR Assistance ! Any suggestions ? |
Wed Dec 08 2010 8:52am |
Sorry, no...but sounds like same problem as mine; if you get a solution from LR assistance can you please let me know. Thanks. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis. IN THE GARAGE: BMW i8 - the mid-life crisis continues and it's great fun. |
Wed Dec 08 2010 9:03am |
Will do . Also,got a message yesterday in display-"Water in Fuel " perhaps related ? But disappeared. |
Wed Dec 08 2010 9:19am |
No. I've not had that. In fact I've had no warnings at all. It just turns over, fires for a couple of seconds, then dies. So far it has finally started each time after about 10 to 15 attempts, apart from last Friday when I gave up because I was late for a meeting and used another car. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis. IN THE GARAGE: BMW i8 - the mid-life crisis continues and it's great fun. |
Wed Dec 08 2010 9:22am |
Patrol arrived -could not fix and LR have arranged for uplift tomorrow-as they are so busy! Could not diagnose
Wed Dec 08 2010 4:55pm |
Thanks for the update but sorry to hear you've not got it sorted. What are the symptoms - does it fire up at all? 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis. IN THE GARAGE: BMW i8 - the mid-life crisis continues and it's great fun. |
Wed Dec 08 2010 4:56pm |
Symptoms: usual starting procedure ,message advising cold starting...then clicks and off.Not firing at all,
Wed Dec 08 2010 5:06pm |
Ah...not the same as mine then. Mine fires for a couple of seconds then stops. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis. IN THE GARAGE: BMW i8 - the mid-life crisis continues and it's great fun. |
Wed Dec 08 2010 5:08pm |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 |
Mine had this and I had to have a new started motor which cured it. Starts first time every time now. Must be a common issue with the MY10 TDV8 as I had to wait for the part as it was on back order. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award 2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys 2009 TDV6 3.0 HSE Buckingham Blue - GONE |
Wed Dec 08 2010 10:34pm |
Update: happened again this morning so got LR Assist out. Couldn't find a specific fault but agreed that there was a problem as it wouldn't start Mechanic has written a report and I've now booked it in with my local dealer (earliest they could get it in with a loan car was next Thursday ). Best guess is a faulty glow plug. I'll keep you posted. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Thu Dec 09 2010 6:49pm |
LR Assist chap arrived tonight at 5.00pm -he got it started ! Suggested it was alternator ! Off now on recovery wagon -will keep you posted when i hear from dealership tomoorrow. |
Thu Dec 09 2010 8:26pm |
