Home > Technical > Cold starting problem TDV8
Page 2 of 5 <12345>
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Hi, had the same problem with our Sprinter Van this week, had the guy from Merc out who ran a thorough check on all injectors and found one leaking, it could be that you have a faulty injector. These new high pressure systems require full pressure to start properly. My TD6 Range Rover had a full failure of all 6 injectors when only 6 months old! Just an idea Idea
Post #281933 Sat Dec 04 2010 12:31pm
Old Stager
United Kingdom 2010 Range Rover Sport TDV8 HSE Zermatt Silver
Now...I've got a confession to make Embarassed Having now read the manual (!) it says if the car repeatedly fails to start you should keep the start button (and brake pedal) pressed until it starts (rather than pressing and releasing the button immediately as you would with a normal start). I will try this next time I have the starting problem; hopefully it will cure it.
Memo to self: RTFM Exclamation
But many thanks anyway for all of the advice Thumbs Up 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
IN THE GARAGE: BMW i8 - the mid-life crisis continues and it's great fun.
Post #282045 Sun Dec 05 2010 9:54pm
Old Stager
I take it all back. -10C this moring and we're back to square one; it took about 12 attempts to start, even with finger planted on the button as per the manual. Spoken to two local dealers. Both agreed it's not right and both suggested I call Land Rover Assistance if (when!) it happens again, because by the time the dealer can have the vehicle in, the chances are the weather will be warmer and they won't be able to replicate the fault. They say it's unlikely that any fault code will be stored as a) there is no warning given on the dashboard; and b) the engine isn't starting so won't recored a fault Big Cry 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #282237 Tue Dec 07 2010 3:34pm
Tboner
Take it to the dealer get a loan car get them to leave it out in the cold and let them try it / sort it, they have more access to tek than the assist cars do surely 2014 5.0SC AB
Gone 5.0 SC
Post #282290 Tue Dec 07 2010 11:26pm
greg
2008 Range Rover Sport TDV8 HST Stornoway Grey
New 2010 TDV8 Autobiography - refuses to start -currently -11degrees-waiting for LR Assistance ! Any suggestions ?
Post #282311 Wed Dec 08 2010 8:52am
Old Stager
Sorry, no...but sounds like same problem as mine; if you get a solution from LR assistance can you please let me know. Thanks. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #282312 Wed Dec 08 2010 9:03am
greg
Will do . Also,got a message yesterday in display-"Water in Fuel " perhaps related ? But disappeared.
Post #282313 Wed Dec 08 2010 9:19am
Old Stager
No. I've not had that. In fact I've had no warnings at all. It just turns over, fires for a couple of seconds, then dies. So far it has finally started each time after about 10 to 15 attempts, apart from last Friday when I gave up because I was late for a meeting and used another car. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #282314 Wed Dec 08 2010 9:22am
greg
Patrol arrived -could not fix and LR have arranged for uplift tomorrow-as they are so busy! Could not diagnose
fault.
Disco arrived this afternoon as replacement.
Post #282371 Wed Dec 08 2010 4:55pm
Old Stager
fault.
Thanks for the update but sorry to hear you've not got it sorted. What are the symptoms - does it fire up at all? 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #282372 Wed Dec 08 2010 4:56pm
greg
Symptoms: usual starting procedure ,message advising cold starting...then clicks and off.Not firing at all,
will post update when goes into dealership tomorrow.
Post #282376 Wed Dec 08 2010 5:06pm
Old Stager
Ah...not the same as mine then. Mine fires for a couple of seconds then stops. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #282378 Wed Dec 08 2010 5:08pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Mine had this and I had to have a new started motor which cured it. Starts first time every time now. Must be a common issue with the MY10 TDV8 as I had to wait for the part as it was on back order. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #282443 Wed Dec 08 2010 10:34pm
Old Stager
Update: happened again this morning so got LR Assist out. Couldn't find a specific fault but agreed that there was a problem as it wouldn't start Confused Mechanic has written a report and I've now booked it in with my local dealer (earliest they could get it in with a loan car was next Thursday Crying or Very sad ). Best guess is a faulty glow plug. I'll keep you posted. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #282547 Thu Dec 09 2010 6:49pm
greg
LR Assist chap arrived tonight at 5.00pm -he got it started ! Suggested it was alternator ! Off now on recovery wagon -will keep you posted when i hear from dealership tomoorrow.
Post #282566 Thu Dec 09 2010 8:26pm
Page 2 of 5 <12345>
