Home > Technical > (INSTALLED) HDS4U, GVIF Interface + Reversing Camera!
zb
2006 Range Rover Sport TDV6 HSE Java Black
whats the button for?
does it automatically come on screen if you select reverse gear?
Post #288213 Sun Feb 06 2011 7:16pm
Rislar
The unit has 3 channels for TV or the like! The button is to switch them or have the camera on at all times!! It also does remote switch when put in reverse!! If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #288214 Sun Feb 06 2011 7:38pm
zb
so if im watching a dvd it on main screen it will come on?
or do i need to hit the nav screen button first?
Post #288222 Sun Feb 06 2011 8:42pm
dazsear
The unit has a dedicated reversing cam feed input (plus the other 3 AV ones) and reversing light +12v feed which you connect to the reversing lights, this allows the unit to automatically switch the display to the reversing camera when reverse is selected.
The below link is the for the forumn discount for the unit AND a reversing camera for �249.
http://www.hids4u.co.uk/Land-Rover-Discove...creen.html
I have to say the D3 site is a bloody good source of information, even if you dont have a D3!
Hope this helps
Daz Thumbs Up 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #288236 Sun Feb 06 2011 10:11pm
christophebcn
Spain
Hello,
i bought the same camera but now i'm confused on how to pass the wires up the rear window...
there's no plastic trim to hide them in, just a small tube (?) running along the side of the window where i assume are located the light and tailgate switch wires. It looks glued to the window and i don't want to damage it.
Did you manage to pass your camera cables in there? any advice on how to do it?
Thanks
Post #292222 Mon Mar 14 2011 11:20am
jetbags
Re: (INSTALLED) HDS4U, GVIF Interface + Reversing Camera!
Rislar wrote:
Hi all, i had a few hours today so i fitted this, the hard part is getting the cables from the tail gate and finding a live from the sat nav unit, all in all a great job even though it took me 5 hours to complete once i'd got my head around the wiring Shocked Thumbs Up
I'd recommend this in a flash, i just need to tidy the cables and add a Ipod cable now Mr. Green
Screen :
GVIF Unit
Working from the switch and from AV1
Sneaky switch!
Hi
What type of camera did you use for this install??? was it a Cmos or CCD do you know if both work or will only one type be compatable??
Many Thanks
Jetbags
Post #301251 Mon May 30 2011 8:16pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Both will work,but if you have a GVIF unit you will only need the ccd as the GVIF has a parking line option,I fitted a unit and camera on mine last week ,a great bit of kit Thumbs Up
Post #301277 Mon May 30 2011 10:23pm
sport2007
United Kingdom 2010 Range Rover Sport TDV8 HSE Rimini Red
does anyone know how or where to route the wires from the number plate reversing camera on the upper glass tailgate rrs.
it has me baffaled .
thanks big faat phil
Post #465403 Mon Jun 22 2015 8:26pm
Bodsy
Site Sponsor
Yes, there is only one way. Drill a small hole in the plastic where the number plate lights are and run the cable through it (you will have to cut the AV one)
I have a special 2 core + shield cable I use so there only needs to be one cable. It then goes around the outside of the ridge that you see when you lift the upper tailgate, using double sided automotive tape, then it needs to go through the rubber grommet, then it also needs to be fed through the tailgate main rubber grommet and then into the car itself.
It is a real pain to do and can take a while to get it right. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #465404 Mon Jun 22 2015 8:33pm
sport2007
thanks for the replies. I had a very good idea that you could not hide the wires , it would be a Censored looking job.
bigfatphil Thumbs Up Thumbs Up
Post #465602 Wed Jun 24 2015 7:13pm
