Home > Technical > (INSTALLED) HDS4U, GVIF Interface + Reversing Camera! |
zb Member Since: 31 Dec 2010 Location: CI Posts: 72 |
whats the button for?
Sun Feb 06 2011 6:16pm |
Rislar Member Since: 04 Oct 2010 Location: Western Lake District Posts: 194 |
The unit has 3 channels for TV or the like! The button is to switch them or have the camera on at all times!! It also does remote switch when put in reverse!! If it aint broke leave it!
Sun Feb 06 2011 6:38pm |
so if im watching a dvd it on main screen it will come on?
Sun Feb 06 2011 7:42pm |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
The unit has a dedicated reversing cam feed input (plus the other 3 AV ones) and reversing light +12v feed which you connect to the reversing lights, this allows the unit to automatically switch the display to the reversing camera when reverse is selected.
Sun Feb 06 2011 9:11pm |
jetbags Member Since: 29 May 2011 Location: Margate Posts: 144 |
Hi What type of camera did you use for this install??? was it a Cmos or CCD do you know if both work or will only one type be compatable?? Many Thanks Jetbags |
Mon May 30 2011 7:16pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Both will work,but if you have a GVIF unit you will only need the ccd as the GVIF has a parking line option,I fitted a unit and camera on mine last week ,a great bit of kit |
Mon May 30 2011 9:23pm |
sport2007 Member Since: 10 Feb 2015 Location: bt67 Posts: 41 |
does anyone know how or where to route the wires from the number plate reversing camera on the upper glass tailgate rrs.
Mon Jun 22 2015 7:26pm |
Yes, there is only one way. Drill a small hole in the plastic where the number plate lights are and run the cable through it (you will have to cut the AV one)
Mon Jun 22 2015 7:33pm |
thanks for the replies. I had a very good idea that you could not hide the wires , it would be a looking job.
Wed Jun 24 2015 6:13pm |
