Home > Technical > Cold left leg when driving - Could it be Cool Box ? |
Have you tried switching off the cold box to see if that makes any difference? Also is the ball warmer vent under the steering column open or closed? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Oct 28 2010 7:41pm |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 |
Hi Tim
Thu Oct 28 2010 7:55pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
If your having the same cold feeling with both cars......
Thu Oct 28 2010 7:59pm |
I drive other cars from time to time which dont have cool boxes in the centre consoles and dont get the cold feeling.
Thu Oct 28 2010 8:03pm |
Rudskibaliblu Member Since: 05 Feb 2010 Location: Western lake district Posts: 329 |
I get it, its called sciatica. Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Fri Oct 29 2010 6:38am |
I don't seem to have the same problem with other cars so there must be a cold area in the RRS as their was in the Merc SL ?.
Fri Oct 29 2010 6:56am |
Have you checked the vent beneath the steering wheel that blasts air into your groin area? 2005 Zambezi TDV6 - Gone but not forgotten
Fri Oct 29 2010 8:45am |
Yeah, its from the back area of the seat / console not the front. |
Fri Oct 29 2010 9:07am |
is there any air vents for rear passengers in the centre console? possible feed pipe for them maybe loose or possible the rear passenger foot blower under your seat
Fri Oct 29 2010 9:23am |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 |
I believe the problem could be absolutely anywhere in your car because of the way the air circulates around. I might be wrong. Obviously, the best way to find out is to go through the entire inside and see if you can identify any air leaks... you should not have much problems in finding it as you say its only 30 min and your leg is real soar, so the leak must be pretty bad. Vadim A. |
Sat Oct 30 2010 3:34am |
