![]() | Home > Technical > Volume Offset for Different Audio Sources |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
I believe you have to hold the tone button down for a few seconds to get the menu up. That key has two functions based on whether you just press it once or hold it down. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 ![]() ![]() |
That's the thing that lets you change just about everything except the volume as far as I can see (think it might be just for the different inputs too) Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+ Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE ![]() |
Yes sorry I tried it on the way home this evening and I couldn't find any way to adjust the ipod volume. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
sure I have seen this when fumbling about, will have another play purple people eater
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
Only other suggestion I'd have is go into iTunes and make sure all the volumes are the same using soundcheck:
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Or a program called mp3 Gain. Instead of it putting them all to roughly the same you can set what level you want them at, + or - |
