Home > General > Can paddle shift be added after MY10 TDV6 has been built
Naz
Hi guys my MY10 RRS is being delivered next week and I initially didnt like the idea of getting the paddle shift is this possible to easily add on at a later stage? Current: MY 12 HSE Autobiography Kit
Gone: MY10 HSE Rear Ent/Park Heating
Post #259449 Sat Mar 13 2010 6:57pm
Gazzer
'fraid not.... Big Cry
I could go on and say how great it is to use, but I won't. Thumbs Up 2010MY Land Rover Freelander 2 HSE
Santorini Black with Ebony Napoli Leather
Post #259453 Sat Mar 13 2010 7:18pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi
Sorry to be so contradictive but it can, ive fitted the RRS2010 heated wheel and paddles to my D4 a slightly different modification to how i probabaly would fit to a RRS 2010 but it is possibile.
Pete
Post #259513 Sun Mar 14 2010 11:13am
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
So what kind of cost would that be then and could it be fitted to a MY08 rrs supercharged? Razz
Post #259515 Sun Mar 14 2010 11:57am
bellautos
Hi sweetafton
The MY08 car is a different kettle of fish to a MY2010 car, there are a few reasons, the steering wheel is different to start with and the MY08 was never a option in paddle form where as the MY2010 is so is available.
The second part is that the MY08 cars wheel communicates to the rest of the car the car via "Resistive ladder" where as the MY2010 uses LIN Bus "Local interconnect network"
This means that the protocall for the wheel controls are different in the 2 cars and leaves it so it cant be a straight forward swap from MY2010 to MY08 Sad
They have also changes the CAN bus signals on the MY2010 from what would be on your MY08 which is 29Bit CAN to the new Ford protocall which is now 11Bit CAN.
So in a nut shell a MY08 is totally different in build to a MY2010, that said it is still possibile but it would have to use the original wheel and some extra momenteray switches located somehwere in the plastic cowle instead of the real MY2010 paddle set.
If you can find a nice location for some extra switches/buttons in your MY08 car i can tell you how to do it for very little money.
Pete
Post #259516 Sun Mar 14 2010 12:04pm
sweetafton
Cheers pete. Thumbs Up Thumbs Up Bow down
Post #259520 Sun Mar 14 2010 1:18pm
Naz
Thanks for your reply pete, so on my MY10 - assuming i were to acquire a new steering wheel with the paddles what kind of further modificatin would be necessary and how extensive would it be? - not to keen on having too many panels ripped off if you know what i mean. Also any idea of costs?
Thanks in advance
Naz Current: MY 12 HSE Autobiography Kit
Post #259529 Sun Mar 14 2010 3:33pm
bellautos
Hi
The mod can go 2 ways, 1st is a CCF edit to enable them as factory which would be 150+vat, the 2nd is a wireless mod which needs a bit of addon circuirty so would cost a little bit more with fitting.
Re fitting, its a 16mm bolt to hold the wheel on so no panals ripped off lol and even if it were it would be more taken of with caution than ripped off.
RRS Paddle left LR017003 29.24+vat
RRS paddle right LR017004 29.24+vat
Paddle loom LR018555 19.95+vat
RRS wheel leather tip LR016252
RRS wheel heated leather tip LR016253 365.00+vat
Heated wheel clock spring YRC500080 used ONLY if heated wheel is chosen as part of the same upgrade.
RRS right heated switches LR015128 69.95+vat Also if heated wheel is chosen as part of the same upgrade.
Have a read here
http://www.disco3.co.uk/forum/topic43831.h...d+steering
http://www.disco3.co.uk/forum/topic43831.h...p;start=75
Pete
Post #259560 Sun Mar 14 2010 8:30pm
Naz
Thanks for the reply Pete, I shall be in touch when I take delivery . Current: MY 12 HSE Autobiography Kit
Post #259576 Sun Mar 14 2010 11:24pm
jeffhunt
Hi all, I am looking to fit paddle shifters to my 2011 RRS, does anyone know of anywhere on the south coast (Hampshire if poss) that can carry out the necessary recoding for me?
I am (was) a competent mechanic, however ill health has seen me rely more & more on others, so if at all possible I would like them to carry out the fitting & coding.
Thanks in advance
Jeff
Post #439922 Sun Oct 19 2014 2:17pm
simple1
So the bottom line is no it can't be retrofitted to a 2010 car unless you want to a) spend a fortune and b) start messing with canbus and ecu's which I wouldn't do full stop. Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #439926 Sun Oct 19 2014 3:56pm
simple1
Post #439927 Sun Oct 19 2014 3:56pm
Bodsy
Site Sponsor
I can add this.
I'll be in Salisbury at the end of November if that helps?
Do you already have the paddle shift bits? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #439932 Sun Oct 19 2014 4:55pm
Disco_Mikey
As Ian says, it can be done with the correct equipment to enable them Thumbs Up
Post #439934 Sun Oct 19 2014 5:31pm
peterg1965
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
ive had paddle shift in a couple of previous cars (Mini Cooper auto, BMW 335d, BMW 640d, Mercedes GL) I hardly ever used it. It strikes me as being a little gimmicky especially if you use your car every day in 'normal' usage. On the track maybe different. Modern Autos are generally pretty good at being in the right gear at the right time.
I test drove my new RRS yesterday and didn't even think about trying the paddles. Am I missing something regarding use of paddles in a Range Rover? Range Rover - 4.4SDV8 Autobiography - Corris and Black
MY12 SDV6 HSE - Buckingham Blue and Ivory leather - NOW GONE
Post #439937 Sun Oct 19 2014 6:04pm
