Home > General > Can paddle shift be added after MY10 TDV6 has been built |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2794 |
As above - I now have the habit of tapping the left paddle when I know I'm gonna need a quick pull away I also find I go into XBOX mode soon after everything else just disappears in the rear view mirror 16MY Estoril Blue SVR.............
Sun Oct 19 2014 8:06pm |
jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83 |
Thu Dec 25 2014 9:33am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
The loom plugs into the R/H switch pack, takes its power from there |
Thu Dec 25 2014 10:10am |
Thanks for that Disco Mikey, I didn't want to have to strip it down to look then have to reassemble to await more parts.
Thu Dec 25 2014 10:24am |
It only takes 30 seconds to strip, have a look and rebuild again |
Thu Dec 25 2014 12:08pm |
Help, the that I brought the bits off (picutre above) lost the rear steering wheel cowl/shroud/cover so sent me something that is definately not the right part. Despite getting in touch the seller has not managed to resolve this. I have googled for the correct part numbers, but no joy whatsoever.
Wed Jan 07 2015 12:35pm |
So the paddle changers are all fitted and working, without some problems:
Fri Jan 16 2015 6:35pm |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
Fri Jan 16 2015 7:25pm |
Hi all, so the paddle change has worked well for a month or so, today they decided to stop working. If i use them immediately after setting off they will work for a while, if i dont, then they wont work at all.
Fri Feb 27 2015 7:47am |
