Home > General > Can paddle shift be added after MY10 TDV6 has been built
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
I use the paddles a lot.
Mainly use them when the car hasn't warmed up just to reduce stress on engine/gearbox, moving from lights/ standstill and when looking to overtake. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #439945 Sun Oct 19 2014 7:52pm
PEACHY
As above - I now have the habit of tapping the left paddle when I know I'm gonna need a quick pull away Thumbs Up I also find I go into XBOX mode soon after Rolling with laughter Rolling with laughter everything else just disappears in the rear view mirror Whistle 16MY Estoril Blue SVR.............
Post #439947 Sun Oct 19 2014 8:06pm
jeffhunt
Hi Guys, I have just got this off eBay to fit to my MY11. I have the IIDTool to activate them etc.
Is this all I'll need to get them fitted, I ask because the loom, where it will connect to the rotary coupling, looks a little short to reach through the steering wheel to the connection socket.
I have not seen inside the wheel yet, so hopefully one of you guys has done this before and can throw some light on it for me.
Will it need an extension lead fitted?
Can anyone advise.
Cheers, have a great Christmas Day all.
Jeff
Post #446379 Thu Dec 25 2014 9:33am
Disco_Mikey
The loom plugs into the R/H switch pack, takes its power from there Thumbs Up
Post #446381 Thu Dec 25 2014 10:10am
jeffhunt
Thanks for that Disco Mikey, I didn't want to have to strip it down to look then have to reassemble to await more parts.
Your a gent
Have a great Christmas
Jeff
Post #446383 Thu Dec 25 2014 10:24am
Disco_Mikey
It only takes 30 seconds to strip, have a look and rebuild again Thumbs Up
Post #446388 Thu Dec 25 2014 12:08pm
jeffhunt
Help, the Censored that I brought the bits off (picutre above) lost the rear steering wheel cowl/shroud/cover so sent me something that is definately not the right part. Despite getting in touch the seller has not managed to resolve this. I have googled for the correct part numbers, but no joy whatsoever.
Does anyone know the part number for the rear plastic cover for the paddle change steering wheel?
Thanks guys
Jeff
Post #447678 Wed Jan 07 2015 12:35pm
jeffhunt
All Fitted
So the paddle changers are all fitted and working, without some problems:
I brought the specific L/R screws to attach the paddle changers to the steering wheel, (chose them of a parts diagram showing them entering the paddle switches). The screws sent were the wrong length, he first on snapped off in the casting..... Luckily I had some self tappers lying around, just not black anodised.
The loom had to be fitted into the left switch pack (I was told the connection was to the right side), at first I thought I'd been sent another dodgy part, as when I brought the kit they sent the wrong rear steering wheel cowl. After a bit of looking around I noticed the socket on the left side.
Programmed the CCF and all works fine now.
Post #448673 Fri Jan 16 2015 6:35pm
aljo
Post #448676 Fri Jan 16 2015 7:25pm
jeffhunt
What Now
Hi all, so the paddle change has worked well for a month or so, today they decided to stop working. If i use them immediately after setting off they will work for a while, if i dont, then they wont work at all.
This morning the down shift worked but the upshift wouldn't i then got a gearbox fault warning....
Plugged in the IIDTool and was presented with the following:
TCM-Transmission 6spd
U0140-68 (2C) Lost communication with body control module - Algorithm based failure - event information
BCM-Body Control
B112B-96 (2C) Steering wheel module - Component failure - internal failure
Anyone with any ideas.
Should I try disabling then re-enable them? Or, with the stering wheel module failure, should i take it all apart to check for a bad connection?
Has anyone come across this before? I'm hoping its an easy fix...........
Post #453994 Fri Feb 27 2015 7:47am
