![]() | Home > Technical > REAR TENDS TO SIT HIGHER THAN THE FRONT |
It does, but it could be that you have a faulty ride height sensor. Worth dropping into your service dept - if they are faulty, they can be replaced under warranty |
BIG BAD RANGE Member Since: 24 Nov 2005 Location: KENT Posts: 64 ![]() ![]() |
Hi had the ride height sensors replaced last week as a recall , so that has been done... |
Has it happened since then? Or was already happening? |
To be fair i have just noticed it , whilst it was sitting on my gravel driveway. |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Depends if it is entry level, standard ride height or full off road height you are talking about. The entry level and off road heights are standard heights pre-programmed on a threshhold within ECU done on a calculation. The standard ride height can be reset - if you ask the dealers they can reset it for you. They have a special tool that measures from the lower suspension bush bolt to the floor and you enter the 4 corner measurements into the laptop screen and it re-calibrates through the RHCM - Ride Height Control Module.
