![]() | Home > General > side step silver trim missing !!! |
m14rsh Member Since: 26 Sep 2010 Location: Norwich Posts: 98 ![]() ![]() |
Just ordered my set of side steps so will have a good look at them before installing and perhaps modify to prevent them falling off if I can. May even put up some pics of it to aid others throughout the process.
landy2010 Member Since: 16 Feb 2011 Location: UK Posts: 9 ![]() |
my silver trim has fallen off but i have it in tact - i will try using self tapping screws to reattach it- but there are not any existing holes on the silver trim so how do i attach that to the black side step anyone got any recommendations- do i need to drill a hole into the aliminum and then use the screw? |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
I also wondered this as one of mine has fell off.
RR RRS Member Since: 24 Sep 2014 Location: Northants Posts: 13 ![]() ![]() |
Anyone recommend aize and diameter of self tapping/roof screws to use please. Mine have come off! |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi guys, looked under mine and there was 6 x 1/8 rivets holding them on each s/step just about !! have drilled them out and replaced with some 3/16 rivets and its now got them fixed solid, quick and easy to do |
aldomaximillian Member Since: 30 Mar 2015 Location: Manchester Posts: 14 ![]() ![]() ![]() |
Hey Steve. Which side is it? I might have a spare one. |
all sorted and I thought I'd do a write up:
Good write-up |
MrGimper Member Since: 05 Jun 2016 Location: Andover Posts: 57 ![]() ![]() ![]() |
Thanks for the write up.... my strips have started to come away at the front and back and am pleased to hear it's a common fault with an easy fix. Was worried I'd have to hack it or buy new steps.
