Home > General > side step silver trim missing !!!
Rob Powell
Just read this thread - I gave our lass a telling off cos she reckoned that one of the trims 'just fell off' and I didn't believe her.
luckily she didn't run over the trim so I just pop riveted it back on
never seen any trims for sale apart from with the rest of the step though
Sad
Post #291392 Mon Mar 07 2011 5:25pm
m14rsh
Just ordered my set of side steps so will have a good look at them before installing and perhaps modify to prevent them falling off if I can. May even put up some pics of it to aid others throughout the process.
Could anybody tell me what they are made out of as would like to get them powder coated the same colour as my wheels before installing them too.
Thanks.
Martin 2014 RRS
Post #293112 Mon Mar 21 2011 12:06pm
landy2010
my silver trim has fallen off but i have it in tact - i will try using self tapping screws to reattach it- but there are not any existing holes on the silver trim so how do i attach that to the black side step anyone got any recommendations- do i need to drill a hole into the aliminum and then use the screw?
Post #306805 Wed Jul 20 2011 3:55pm
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
I also wondered this as one of mine has fell off.
There doesnt seem to be anything to screw to from the back?
Any ideas anyone?
Thanks
James
Post #306838 Wed Jul 20 2011 8:19pm
RR RRS
2007 Range Rover Sport TDV6 HSE Stornoway Grey
Anyone recommend aize and diameter of self tapping/roof screws to use please. Mine have come off!
Post #464067 Mon Jun 08 2015 5:48pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi guys, looked under mine and there was 6 x 1/8 rivets holding them on each s/step just about !! have drilled them out and replaced with some 3/16 rivets and its now got them fixed solid, quick and easy to do Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #464070 Mon Jun 08 2015 6:05pm
aldomaximillian
Re: side step silver trim missing !!!
steveb wrote:
the silver trim has fallen off one of my side steps, does anyone know where I can but a replacement without having to buy a new set of complete steps !!
Help please
Hey Steve. Which side is it? I might have a spare one.
Post #464072 Mon Jun 08 2015 6:26pm
RR RRS
all sorted and I thought I'd do a write up:
1. raise car for easy access:
2. chisel off rivets and pop out ends attached to side strip:
3. Self-tapping screws from B&Q used to screw aluminium strip back on to step:
4. all done:
Post #465018 Thu Jun 18 2015 4:54pm
Paddi
Good write-up Thumbs Up
But I hope you put some axle stands under the chassis rails while you were under there as the RRS does have a tendency to drop a little when self-levelling. 2008 MY Java Black TDV8 HSE
Post #465024 Thu Jun 18 2015 5:05pm
MrGimper
England 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Thanks for the write up.... my strips have started to come away at the front and back and am pleased to hear it's a common fault with an easy fix. Was worried I'd have to hack it or buy new steps.
Thanks again Smile
Post #498443 Sat Jun 11 2016 1:02pm
