Home > Technical > SUPPLEMENTARY FUSE BOX NOT IN LUGGAGE/BOOT AREA???
Ambrez
hello, need help guys......
number plate bulb went on my 2005 sport, went to change it and shorted it out by accident.
now i have no number plate lights or a rear left hand side light.
this matches up with the manual saying FUSE NUMBER 6 has gone and they short out together
but cant find the supplementary fuse box at all.... looked in all boot compartment
i do have aftermarket dvd screen's so unless they moved it to somwhere else?
anyone she any light on this... very much appreciated
Ambrez
Post #244051 Mon Nov 30 2009 9:30pm
Texstar
Are you sure the fuse you want isn't in the fusebox fwd of the glovebox? Supplementary one (rear l/h side) I thought, was only fitted if you have the towing electrics fitted. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #244053 Mon Nov 30 2009 9:58pm
Ambrez
the fuse im looking for is....... rear number plate bulbs/ left hand side rear lamp??
Post #244055 Mon Nov 30 2009 10:00pm
Texstar
Ambrez, open the glove box fully to expose the fusebox, there is a guide there as to what the fuses are for, I think it'll be there somewhere, not at the back of the car. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #244056 Mon Nov 30 2009 10:04pm
MAW
Correct Thumbs Up
Post #244057 Mon Nov 30 2009 10:07pm
Ambrez
oh rite ok.....
does anyone which fuse number to change for the number plate bulbs??
thanks in advance
Post #244058 Mon Nov 30 2009 10:14pm
MAW
Confused could it be number 6 - per your post Confused Laughing
Post #244062 Mon Nov 30 2009 10:38pm
Ambrez
number 6 is tow reverse lamp accorgind the manual??
Post #244064 Mon Nov 30 2009 11:11pm
MAW
I am sure it is in the manual - i wouldn't know off the top of my head Confused
Pull what you think it is and check IIRC if blown they are visible
Post #244065 Mon Nov 30 2009 11:16pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
Also directly there in the glovebox is the guide for which fuse operates which item.
Just be careful not to break your glovebox trying to lower it...squeeze the two items gently and lower the box.
Putting back up is cinch, just push up and the box snaps back into place. PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #244068 Tue Dec 01 2009 1:42am
RRS_TT
Trinidad And Tobago 2006 Range Rover Sport TDV6 HSE Java Black
Hi all, I am having the same problem, the owners manual I have says to look for the fuse in the boot area, and the list of fuses in the glove box does not state a fuse for the licenses plate light. HELP PLEASE ! Shocked Shocked Shocked Beautiful Today was the Tommorow you worried about Yesterday
Post #244152 Wed Dec 02 2009 1:53am
Ambrez
now sorted.
nothing to do with fuses in the boot area,
was F4 10amp fuse in front
Post #244521 Sat Dec 05 2009 1:05pm
RRS_TT
thanks Razz Beautiful Today was the Tommorow you worried about Yesterday
Post #244538 Sat Dec 05 2009 5:57pm
