![]() | Home > Technical > Range Rover Sport *STEREO PROBLEM*? |
bananenschale Member Since: 03 Jan 2009 Location: Moenchengladbach Posts: 178 ![]() ![]() ![]() |
Thats normal! it saves the battery. i use my radio in munich riem at the flea market |
amd2005leasing Member Since: 14 Apr 2009 Location: MÜNCHEN Posts: 10 ![]() ![]() ![]() |
Hallo bananenschale !!!
Unter der fahrt sollte das nicht passieren. Evtl. ladet die Batterie nicht richtig. Könnte dann an der LIMA liegen. Ist aber nur reine Spekulation. Evtl. mal den Fehlercode auslesen lassen. Bei mir ging z.B. einmal das Radio nicht. Ging an, aber kam kein Sound raus. Halben Tag! Fahr zu LR, auf dem Parkplatz mach ich das Radio nochmal an und da gings.. Also evtl. mal hinfahren und das Teil geht wieder von sich aus |
terrieremery Member Since: 07 Dec 2008 Location: devon Posts: 35 ![]() ![]() ![]() |
try turning it up gradualy |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
Stop talking German, zhe Brits ar afraid of a German Verschwörung if you don't talk Englisch and you don't want them to be frightened, do you?! |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Whilst i do not get the lower power message, mine has been doing exactly the same, it has had a new battery, a new radio, and the latest thought pattern is maybe it has a misrouted cable loom in the cabin under the front seats that may be crushed, i believe it was a manufacturing issue. Will keep you posted on the cable loom front, it is in next monday for 2/3 days to see if that is the issue, it requires a front of cabin strip down.
