![]() | Home > Technical > tracking advice????? |
That's why the warranty people don't approve of fitting anything bigger than 20's. The car isn't designed to take anything larger as it puts additional stress on the drive train and invalidates any factory warranty you might have had..................................... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
v111hst Member Since: 05 Jun 2009 Location: midlands Posts: 10 ![]() |
is there anything i can do??? or am i stuffed |
Try using the Search function on the orange tool bar at the top of the page because tracking has been a fairly frequent topic in the past. Many early RRS's suffered from horrendous tyre wear straight out of the factory - then allegedly the factory found tons of wheel balance weights lying under the gratings at the end of the production line............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
thanks i'll have a look |
mr boombastic Member Since: 08 Dec 2007 Location: NSW Posts: 40 ![]() ![]() |
I have 22in wheels on my sport and i have not had any problems with tracking and balancing. I had them put on when i purchased nearly 1.5 years ago. I had 20inch wheels on my previous car that came with 16inch wheels as standard and i had that car for nearly 6 years with no problems. So i am not quite in agreement with Tim in relation to putting addition stress on the drive train, especially as the Sport is supposed to be a far more robust vehicle. |
Coolj Member Since: 27 Aug 2007 Location: London Posts: 85 ![]() ![]() ![]() |
V, You should try Protyre centre. I use them for my 22" wheels. Most dealers do not have the correct equipment for aligning and balancing 22" wheels as I found out. Use their website to locate the centre nearest to you.
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
My car has similar at the moment and I'm just running the factory 18's.. My dealer is trying to say it is the road camber... Funny that it didn't do this in the first year of ownership on the same roads! |
pj_evo Member Since: 24 Jun 2009 Location: South Coast Posts: 11 ![]() ![]() ![]() |
My steering wheel is ever so slightly off to the left as wheel.
wullie Member Since: 27 Mar 2009 Location: Ayrshire Posts: 81 ![]() ![]() ![]() |
Hi, two simple things to try. Find a good road with not much of a camber if there is such a thing in the UK, drive down the centre of the road (watch out for other motors though) you should be able to let your steering wheel go or hold very lightly and the rr should continue on fairly straight, or drive down a one way street on the right see what the rr does, !pull left or right!
rockportpurple Member Since: 30 Apr 2009 Location: scarborough Posts: 26 ![]() ![]() ![]() |
hi all i had my wheels tracked up yesterday at just car clinic as there lazer equipment does anything up to 24inch wheels,i found it out by accident after searching round lots off tyre fitters,but i was also told you can track up with the original wheels,and the fit the 22's, if you dont have it tracked up the wheel position sensers tell the vehicle the wheel isnt straight and shuts down the Hdc/dsc/air suspension,all 4x4 systems,as mine did two days ago,it cost £45 to have it done,but any body shop with wheel alignment can do it,hope this helps |
ciaa Member Since: 31 Mar 2009 Location: Dubai Posts: 70 ![]() ![]() ![]() |
Hi
