Home > Maintenance & Modifications > Tools to Replace front brake pads? |
You mean this? Hope its the same for your later model! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Wed Dec 02 2009 8:28pm |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 |
Sorry Bobby, any chance of a rear change pdf too (non Brembo)?
Thu Jan 28 2010 4:30pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Yes on the sensor issue - if it hasn't worn through you can re use - ie you can use it if worn but to a certain amount |
Thu Jan 28 2010 5:04pm |
Cheers MAW, slowly getting my parts and knowledge sorted for the DIY service - |
Thu Jan 28 2010 5:25pm |
MAW you must be the brake expert, or certainly lead poster!!!!
Thu Jan 28 2010 7:01pm |
Rear Brake Pads Malaysia Boleh!
Thu Jan 28 2010 8:48pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Not entirley certain but is there not some procedure involved on the rear set up with the EPB mechanism and making sure it is re-adjusted |
Thu Jan 28 2010 8:54pm |
No, I don't think so. The EPB components are in the drum and you're not going there just to change the disc pads.
Thu Jan 28 2010 9:04pm |
