Home > Maintenance & Modifications > New Procedure for fixing Knocking Suspension |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
Many thanks.
Sun Oct 20 2013 8:45am |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 |
This might be a daft question but do Land Rover pay for this work to be done, |
Wed Apr 02 2014 10:36am |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
had the ARB replaced by land rover and the noise is still there
Thu Jul 24 2014 8:06am |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
When you said "replaced ARB" - was it just the bushings ? I think the bushing would squeak when old - but it would have to be very worn for the roll bar itself to knock against the chassis mounting point ? Did you ask them to keep the old bushings to see their condition. I had a clunk coming from the front suspension in my BMW E46 - driving straight at 30-40MPH down uneven road. I saw an episode of wheeler/dealers where they replaced sway bar drop links to fix a similar problem. I purchased a couple of $18 Delphi drop links - had them installed - did the ARB bushings at the same time - and fixed the problem. Old bushings looked fine - and it was hard to tell how worn the drop links were - but if the bushing in there is worn - you will have metal to metal contact in the link - and this will cause a knocking noise. I think those parts are cheap on the RRS too - and should be replaced (on standard - not active system at least) - not just the roll bar bushings themselves.
Thu Sep 18 2014 3:52am |
You guys that have had this done successfully and now have a perfectly quiet car, how much did you pay for this fix? |
Sat Jan 31 2015 4:41pm |
mal1721 Member Since: 27 Nov 2020 Location: Hampshire Posts: 20 |
Has no one else had these issues since the last thread some years ago? I have an annoying clunking which no one can seem to find, in fact the 3 garages I've tried here in Hampshire UK have very little interest and just shrug their shoulders. |
Mon Feb 01 2021 8:40am |
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 |
Gaz
Mon Feb 01 2021 9:35am |
OOPS, sorry replied by mistake |
Mon Feb 01 2021 11:13am |
Hi Mal,
Mon Feb 01 2021 11:53am |
Sorry I should have included a link to the technical bulletin
Mon Feb 01 2021 12:01pm |
Lee, thats brilliant thank you. Yo have given me somewhere to start and I've downloaded the bulletin, priced the parts and have someone looking at it who is a Range Rover specialist on Thursday.
Mon Feb 01 2021 1:27pm |
