![]() | Home > General > Common suspension fault. and general impressions....question |
TikoV Member Since: 10 Mar 2009 Location: Glasgow Posts: 114 ![]() ![]() |
Hi folks,
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
You need to get the new ball joints and also have the bushes replaced |
Am I facing an uphill battle in getting the $tealers to admit they need changing. Obviously, I'll be gon well equipped with all the various literature and comments made here. Regards Tiko Currently 2009 BMW 335d m sport coupe 'evolve' 1998 BMW M3 Evo track prepared Due/Wishlist MY10....once I find one |
Shouldn't be a problem - it's a known issue, but take a copy of the relevant TSB if they make a fuss. |
Leo, excuse my ignorance or naiveity but what exactly is TSB?
Technicai Service Bulletin - LR release instructions to dealers on how to repair faults etc. Some members here have access to the on-line reference library - helps when dealing with dealers who claim faults are normal.
Many thanks....fot your help
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
It's not an issue for the Dealers anymore since LR have provided a solution......New design ball joints and new design bushes. So as long as they fit the latest versions it should be quiet. A warranty job.
Frozen of Wiltshire Member Since: 08 Jan 2009 Location: Wiltshire Posts: 66 ![]() ![]() ![]() |
TikoV,
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Would think your warranty will be invalid if you take it in on 22inch rims as these are not recomended by Landrover |
This is where I'm worried.......then again, I bought the vehicle as is and never knew that these wheels weren't recommended. If it becomes an issue, I have a set I can borrow if needs must. Tiko Currently 2009 BMW 335d m sport coupe 'evolve' 1998 BMW M3 Evo track prepared Due/Wishlist MY10....once I find one |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
Good luck with that............us old timers to this issue have yet to be convinced. My car is now effectively bionic and I still have the noise |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
unless you have experience of dealers refusing to do work on your car because of 22s then i wouldnt advise people to remove them before going to the dealers especially for the common knocking noise i have them on mine its been in to get the new bushes an ball joints done and a few other things and they have never mentioned them has any 1 ever actually been refused warranty work because of having 22s on |
Some dealers don't worry, others do... certainly dealers have been known to refuse warranty claims on larger than recommended alloys. |
