![]() | Home > General > driving style question - using the electronic hand brake |
Korenai Member Since: 05 Oct 2008 Location: Lugano Posts: 244 ![]() ![]() ![]() |
I use it only when the car is parked somewhere steep... Quite useless, since even with just the lever on P the car will stay in its place, but it looks safer to me, I don't know... ![]() |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Thanks guys... |
Neil Edwards Member Since: 23 Jan 2009 Location: Bucks Posts: 3 ![]() ![]() |
I have just experienced a major problem with my handbrake,it just locked on when Iwas driving along normally,local dealer said this was due to lack of adjustment,interestingly the first question they asked was if I drove off with the brake on.They told me that this should never be done as it strains the shoes and takes them out of alignment,when I pointed out that the handbook says you can do this they replied that they were hoping to get this changed in the handbook.
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Neil, Sorry but that's a load of B S |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
When the A8 got the EHB a driving instructor once showed me how well this works: When I was driving at 70 mph he pulled the thing. The car stopped so fast (and surprisingly safe since the ABS works, too) I had a big red stripe from the seat belt on my chest. ![]() Thank god they invented the belt-load limiter before the EHB, otherwise this test could brake some rips! ![]() ![]() ![]() |
Thanks Josh,you may be correct but I am only passing on what they said!! for information they replaced discs&pads,drums and shoes and sensors,not bad for a vehicle with only 23500 mls on it. |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Over on rr.net, Blackbox Solutions posted the details of a CCF (car config file) from a Sport. One of the options listed in the file is "EPB City Mode: Disabled"... We don't know what that is or what it does when enabled, but we have guessed it may be some sort of automatic parking brake engaging after you have stopped at intersections for a set amount of time?
There appears to have been some sort of redesign of the EPB as I haven't had any jamming on, screaching and howling with the TDv8 like I had with the TDv6.......................... mind you the TDv8 hasn't been offroaded, whereas my Tdv6 was shown a bit of mud in it's wheelarches on a few occassions. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Is it perfectly safe to exit and leave the car parked, even on a slope, just held by the gearbox in 'P'?? |
I'm on my second RRS and it's the 2nd that has automatically applied the EPB after I have left the car for few minutes so I wouldn't worry about 2nd. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
![]() I may be wrong ![]() ![]() TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Josh, I'm not sure of this, but you could just be right |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Umberto...you're a genius with this stuff, but I'll be damned if I can figure out how that picture suggests that there is an electronic connection to engage the front disc brakes as well when the car is rolling faster than 6 mph...
