Home > General > Glovebox Light
Mintleaf
Glovebox Light
Does anyone know if there is a light in the glovebox? My manual shows a replacement bulb for the glovebox but i dont seem to even have a light in mine... RR Sport TDV6 HSE 07MY Java Black
Post #206722 Mon Jan 19 2009 12:05am
MX
United Kingdom 2008 Range Rover Sport TDV6 SE Java Black
yes there is - in the larger one...the one at the top of the dash doesnt light up in mine RRS TDV6 SE Java Black +towpack +tintent +Permagrin
What a difference between this and my old Disco3
Formerly mxgeldar7
Post #206723 Mon Jan 19 2009 12:27am
640Newton
Australia 2008 Range Rover Sport TDV8 HSE Stornoway Grey
There is no light in the top glovebox but there is in the larger lower glovebox. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres.
Post #206729 Mon Jan 19 2009 5:38am
Mintleaf
Thanks for the replies - i have double checked the lower glovebox and can't even see where the bub should go...looks like i didnt get one! Sad RR Sport TDV6 HSE 07MY Java Black
Post #206740 Mon Jan 19 2009 9:09am
640Newton
when you open the glovebox you should see two plastic prongs on the dash side. One is the clip for the glovebox latch and the other is a longer round pin-like prong. You should be able to push that prong in as this is the switch for the lamp. If that prong is there then you have the light but the bulb has blown.
The bulb is located behind where those two prongs are located, tucked right up underneath out of view. I can try and take photos if you'd like? 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres.
Post #206745 Mon Jan 19 2009 9:31am
Mintleaf
Thanks Mate, I have the prong so will double check again to see if i can find the bulb - cheers... RR Sport TDV6 HSE 07MY Java Black
Post #206747 Mon Jan 19 2009 9:37am
640Newton
stick your finger into the gap directly behind the prong that triggers the light as it lives up there. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres.
Post #206750 Mon Jan 19 2009 9:42am
Bobby
It could be..
1. bulb failure,
2. fuse blown,
3. circuit fault, or
4. switch fault.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #206775 Mon Jan 19 2009 10:28am
Mintleaf
Thanks Bobby, do you know if the glovebox light circuit is connected to the ashtray light / cigarette lighter? I noticed they are not working either and the fuse is fine...Cheers RR Sport TDV6 HSE 07MY Java Black
Post #206776 Mon Jan 19 2009 10:31am
Bobby
I'm not sure about the circuit but I think the glove compartment light, map reading lamps and vanity mirror lamps share the same fuse (10A).
I'll see if I can find any circuit diagrams! Malaysia Boleh!
Post #206789 Mon Jan 19 2009 10:46am
larsh
Norway 2006 Range Rover Sport TDV6 HSE Java Black
The topic is a bit old, but maybe someone are interested in a top up with some pictures.
If the lamp is broken, why not replace it with a 5-LED wedge lamp, like this one:
This LED will draw 0.75W instead of the original 5W, and does not get hot.
As mentioned in the discussion, the glovebox lamp is very well hidden:
Instead of trying to get the bulb out from the nearly invisible socket, the whole socket can be taken out.
Use a small screwdriver or plier to loosen it from the panel. Your child's small fingers might be helpful to get hold of the loose socket from behind the panel:
Cable & plug is still attached to the socket. To get it off, use a plier to press in the plug's locking tab while pulling the cable:
The LED replacement does not reach the bottom of the socket, unless you cut off the small tabs supporting the original bulb:
Now it's all the way in:
Plug the cable back in the socket. Check that the rest of the interior lamps are on. If no light from the LED, take it out of the socket, turn it 180 degrees and put it back.
Now, try to get the assembly back in place (your child's small fingers again).
After this, replacing the rest of the interior lamps is a piece of cake Wink
Post #314774 Thu Sep 22 2011 8:37pm
Another ford part used Whistle I didn't realise when buying my sport that it was made up of all the spare parts that ford had left over. Big Cry
Post #363248 Thu Nov 15 2012 2:05pm
Laughing I noticed that. Sad
Still look on the bright side, at least it works when the glovebox opens. Not sure a JLR branded one would have such reliability Whistle Laughing ON THE WAY: BMW F21 M140i
Post #363250 Thu Nov 15 2012 2:09pm
Rolling with laughter Is that avatar your new mode of transport that you've bought for woodie Question Laughing
Post #363259 Thu Nov 15 2012 2:33pm
#76
Great update Larsh!, just what i needed to know to put the final bulb in!.
Top tip!.
Thumbs Up TDV8
Custom map & K&N
Straight through Exhaust
...Awesome!.
Post #363260 Thu Nov 15 2012 2:35pm
