![]() | Home > General > Glovebox Light |
MX Member Since: 06 Mar 2008 Location: Been to Moscow, beat the blues....what next? Posts: 152 ![]() ![]() ![]() |
yes there is - in the larger one...the one at the top of the dash doesnt light up in mine RRS TDV6 SE Java Black +towpack +tintent +Permagrin
640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231 ![]() ![]() ![]() |
There is no light in the top glovebox but there is in the larger lower glovebox. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres. |
Mintleaf Member Since: 18 Aug 2008 Location: London Posts: 77 ![]() ![]() ![]() |
Thanks for the replies - i have double checked the lower glovebox and can't even see where the bub should go...looks like i didnt get one! |
when you open the glovebox you should see two plastic prongs on the dash side. One is the clip for the glovebox latch and the other is a longer round pin-like prong. You should be able to push that prong in as this is the switch for the lamp. If that prong is there then you have the light but the bulb has blown.
Thanks Mate, I have the prong so will double check again to see if i can find the bulb - cheers... RR Sport TDV6 HSE 07MY Java Black |
stick your finger into the gap directly behind the prong that triggers the light as it lives up there. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres. |
It could be..
Thanks Bobby, do you know if the glovebox light circuit is connected to the ashtray light / cigarette lighter? I noticed they are not working either and the fuse is fine...Cheers RR Sport TDV6 HSE 07MY Java Black |
I'm not sure about the circuit but I think the glove compartment light, map reading lamps and vanity mirror lamps share the same fuse (10A).
larsh Member Since: 22 Sep 2011 Location: Skjetten Posts: 2 ![]() ![]() ![]() |
The topic is a bit old, but maybe someone are interested in a top up with some pictures.
Another ford part used |
#76 Member Since: 30 Oct 2012 Location: Norfolk Posts: 75 ![]() ![]() |
Great update Larsh!, just what i needed to know to put the final bulb in!.
