Home > Technical > Creaky and squeaky noise from front suspension!!!
dadanek
Czech Republic 2007 Range Rover Sport Supercharged Java Black
It is not the known knocking... It is strange creaky noise. It started today. The noise goes from front shock-absorbers, or some others parts - I dont know. It is doing that noise only when i go slow and on rugger road. I also tried to raise the car to off-road mode - it makes that noise! But what worse... the raising of the car is unbeliavably slow! The raising usually takes 5 seconds, but now it takes 1 minute...
Can you help? Did you hear about it?
I think I will have a squeaky trip to dealer... Big Cry RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #191941 Tue Oct 14 2008 2:18pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
A known problem and I too have suffered this one. Normally its a simple replacement of the bushes as they run dry. Dealer will replace and pack with grease. Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #191943 Tue Oct 14 2008 2:35pm
dadanek
Bushes...?? What it is? I cant find it in dictionary. RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #191946 Tue Oct 14 2008 2:41pm
will_wonka
Rubber bushes (or gromits) that are attached and sit at the ends of the anti roll bars. Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #191947 Tue Oct 14 2008 2:43pm
dadanek
Thanks!
Can I drive on it next few thousand km or is it necessary to go to dealer? RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #191950 Tue Oct 14 2008 2:47pm
will_wonka
NP. Fine to drive, just irritating Shocked Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #191951 Tue Oct 14 2008 2:48pm
dadanek
And Is it normal that it raising to off-road mode 1 minute?? RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #191953 Tue Oct 14 2008 2:54pm
will_wonka
That sounds like a different issue and most certainly points to a compressor fault. Best to get that checked at the same time, unless of course you are planning to off road reguarly or sooner, in which case, get her in before venturing in to the wilderness......you never know if its going to fail. 1 minute is far too long and it should take no longer than 5-10 secs. Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #191954 Tue Oct 14 2008 2:58pm
dadanek
I dont think it is compressor, because the rear suspension is in 5 seconds up. But the front suspension reach the offroad mode after minute...
Tomorrow I will call my dealer, again Twisted Evil RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #191955 Tue Oct 14 2008 3:02pm
will_wonka
See what the experts say...let us know dadanek. Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #191956 Tue Oct 14 2008 3:05pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
You may have a small slow leak in the front air suspension causing the slow raising of the front. Question
Post #191987 Wed Oct 15 2008 1:04am
Bobby
I think its these bushes...
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #192095 Thu Oct 16 2008 2:15am
Tim in Scotland
Bobby it's usually an insert of some sort of hardened plastic (in other applications they are made of brass or bronze even) that get inserted into a suspension point or place where wear can occur with two metal surfaces rubber on each other - the bush is "sacrificial" and less expensive/critical a part to replace than the main components.
http://en.wikipedia.org/wiki/Bush_(mechanical)
I think this entry in wikipedia covers ALL the meanings Rolling with laughter
Just be very careful what you type into Google if you do a search there, you need to type in MECHANICAL Bushes.........................
otherwise you will get a lot of hits for George W. Rolling with laughter 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #192107 Thu Oct 16 2008 8:26am
will_wonka
Bobby
Have you got more diagrams of the RRS underpinnings? I am particuarly requiring the ARC unit and front suspension as an overview and the individual components. Question Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #192129 Thu Oct 16 2008 10:44am
Bobby
Tim, many thanks for the educational info on 'bushes'. Thumbs Up
I posted the above diagram because Will suggested that the problem could be 'bush' related and poor dadanek was not sure what 'bushes' meant! Smile
Will must have mentioned 'bushes' because there was a TSB issued way back in 2006. This concerned complaints of creak/squeak noises from the front of the vehicle. Apparently LR suggested replacing the stabilizer bushes with new ones that are impregnated with Teflon, which were just available then! However, this only concerned the RRS Supercharged!
The inserts you mentioned are related to a TSB issued August 2008. This concerns knocks from the front or rear suspension. It seems the stabilizer bushes get compressed, leave a gap and thus causing wear. It is recommended to insert 'strabilizer bar packers' between the bushes and the chassis. But this is for vehicles without ACE! Laughing Malaysia Boleh!
Post #192227 Fri Oct 17 2008 1:54am
