Home > Technical > Phone Cradle Problem
rweintra
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
I have the phone cradle for my Sony Ericsson. The phone works fine with the bluetooth although it drains the battery rather rapidly. I got the cradle to work also, except for one major problem. When I dial with the phone in the cradle i can hear it ring over the speaker system, which is great. BUT, the person on the other end can't hear me. They can't hear me dial a number on the keypad, or anything. Does anybody have any idea what could be wrong? Any input would be greatly appreciated. Just FYI, I tried the phone with a regular, plug-in headset, and that works. So, its not the ports on the phone.
Post #9736 Sat Jan 07 2006 10:13pm
Martin
Site Administrator & Owner
Did you get this from the UK as I never heard back from you? Confused Like this site? Buy some RRSPORT goodies to show your support!
Post #9737 Sat Jan 07 2006 10:15pm
rweintra
Crap!! Sorry, Martin!! Yes!! I got it in last week. A late Christmas present. Guy Salmon in Coventry sent it to me. It wasn't as expensive as expected. It has worked perfectly, except for this most recent issue. Thanks again for all of your help.
Post #9738 Sat Jan 07 2006 10:23pm
Martin
They're not bad lads up in Coventry Wink Like this site? Buy some RRSPORT goodies to show your support!
Post #9739 Sat Jan 07 2006 10:27pm
PaulB
rweintra,
My office is across the road from Guy Salmon, so if you need someone to call in for anything, let me know and I'll be happy to help.
Regards,
Paul RRS TDV8 - Stornoway Grey, Irory Leather with Dark Zebrano, Privacy Glass, Tow Pack.
1967 Cobra 427 S/C
1951 Vincent Comet
2001 Harley Davidson Fat Boy
Post #9752 Sun Jan 08 2006 11:29am
rweintra
So very kind of you. I may ask you to ask the service dept about this issue. The US dealers don't have this part in their stock so they probably won't be able to help me. I simply can't get the microphone to work when the phone is in the cradle. Maybe they would know if it could be a wiring problem, or maybe they have seen this problem in particular with the Sony Ericsson cradles? Any help would be much appreciated.
Post #9756 Sun Jan 08 2006 1:45pm
PaulB
If you PM me all the details, I'll go see them tomorrow for you.
Regards,
1967 Cobra 427 S/C
1951 Vincent Comet
Post #9757 Sun Jan 08 2006 1:51pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
First thing to test is another cradle as these can be faulty. If another one is the same, the next thing to try is the same model phone as yours, in your car. My nokia 6230 had corrupt software issues and I had to replace the phone itself.
If it is still not working, it is more likely to be the PTI system itself playing up and therefore needs dealer attention.
Go through a process of elimination of the easy to swap aspects before you presume the car is at fault.
Good luck. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #9759 Sun Jan 08 2006 1:53pm
rweintra
Tried another phone. It didn't work.
I would be happy to get another cradle, but there are truly none left in the world.
If there are, I'll glady buy another one.
Post #9761 Sun Jan 08 2006 1:58pm
rweintra
PROBLEM SOLVED!!
I have figured out the cradle issue.
The first thing I did was take the cradle apart to make sure that all of the parts inside were solidly together. I firmed up a couple of the solder points and then put it back together. I then realized that the contacts were not making solid contact. So, I cleaned both the contacts on my phone and on the cradle. Wouldn't you know it, it started working. Now, I still can't get my phonebook downloaded, but I can handle that. Onto the next problem, when one arises....
Post #10014 Tue Jan 10 2006 11:49pm
Re: PROBLEM SOLVED!!
rweintra, your like British Rail - your getting there Wink
Post #10036 Wed Jan 11 2006 9:29am
