Home > General > ACC Cruise Control question
G4LAND
Spain
If you have the Adaptive Cruise Control; does it works just that way, or you can use it like the regular Cruise Speed Control, too?
Do you have experience using ACC? How does it work?
I still on time to order that option, and want to know your opinion. Question
Thanks Thumbs Up Yuri
(ARS) XE1UN
13 RANGE ROVER SPORT HSE SDV6
Orkney Grey/Black
(Spain)
07 RANGE ROVER SPORT HSE TDV8
JavaBlack/Black
(SOLD)
05 DISCOVERY 3 G4 V8
(Spain)
02 DEFENDER 90 BLACK LE TD5
(SOLD)
13 FREELANDER 2 (LR2) HSE Lux SI4
Havana/Black
(Mexico)
Post #95066 Mon Mar 19 2007 8:02pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I've gott ACC on mine. Never used it though and don't plan on doing so. If I wanted to hand control of the throttle and brakes to someone or something else - I'd get a taxi ! RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #95076 Mon Mar 19 2007 9:13pm
PauloAmore
Scotland
Re: ACC Cruise Control question
Thanks Thumbs Up
I've only had my RRSport a couple of days but it does have ACC. I love it. Especially good if the car in front starts to brake lightly then harder. The system detects the deceleration rate of the car in front increasing and applies the brakes. Big time hits the brakes. It could brake you from 100 MPH to 20 in a flash.
Only issue with it is that sometimes it detects a truck, on a bend and assumes that the truck is in the same lane and brakes.
You can change the distance between you and the car in front.
Basically, it's cruise control, just safer.
I don't know if you can switch the radar off or not. 2022 P440e AB
Post #95078 Mon Mar 19 2007 9:30pm
tony wright
United Kingdom 2006 Range Rover Sport SDV6 HSE Zambezi Silver
Same here, I think it's great. So relaxing to drive on the Autobahn and just move in and out of traffic with nothing more than a slight turn of the wheel. As mentioned earlier sometimes it can catch you out on the bends.
My biggest gripe with the car is whoever designed the indicator stalk to also act as high beam flash needs shooting. Lost count how many times I've flashed the lights to oncoming traffic while turning Embarassed Maybe mines just ultra sensative
Post #95084 Mon Mar 19 2007 10:16pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Can't turn the radar off to the best of my knowledge. ACC is OK - I use it quite a bit - but it does make for a not-so-smooth ride as it only looks one car ahead of course and hence cannot forecast the flow of the traffic Brakes late and accelerates slowly too.
Post #95115 Mon Mar 19 2007 11:19pm
G4LAND
Spain
It could be interesting, but I have the impression that is not really a developed technology, so has some issues to correct. It can be better if you are able to turn on or off the radar and use like a regular cruise control too.
So; Take it or not????
Question Sheep Sheep Idea Yuri
(ARS) XE1UN
Orkney Grey/Black
(Spain)
JavaBlack/Black
(SOLD)
(Spain)
(SOLD)
Havana/Black
(Mexico)
Post #95321 Tue Mar 20 2007 2:21pm
Not sure it's worth specifying if you're building from scratch... Very Happy
Post #95324 Tue Mar 20 2007 2:23pm
