Home > For Sale & Wanted > TDV8 for sale |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Ah yes the air bag TDV6 - gone
Mon Mar 12 2007 8:29pm |
Ian.Richardson Member Since: 12 Feb 2007 Location: UK Posts: 101 |
You have me wondering.
Mon Mar 12 2007 8:37pm |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
its not a myth ian just be carefull not to drill into it |
Mon Mar 12 2007 8:41pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Yep, as aljo says, be careful with the steering wheel airbag enclosure Ian. However, I did mine the same method as VA and had no problems whatsoever, done in 5 minutes. Small drilled pilot hole penetrates the green tin badge really quickly so dont press too hard! Self-tapper grips the old badge, pull firmly with pliers, badge will ease out slowly. Double-sided sticky pads (or glue) fixes the new badge on the centre space. Easy-peasy! Good Luck! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
Mon Mar 12 2007 9:37pm |
