Home > For Sale & Wanted > TDV8 for sale
Josh
Ah yes the air bag Rolling with laughter Rolling with laughter Rolling with laughter TDV6 - gone
TDV8 - gone
Post #92829 Mon Mar 12 2007 8:29pm
Ian.Richardson
You have me wondering.
Please explain, Is the air bag a myth?
Post #92833 Mon Mar 12 2007 8:37pm
aljo
its not a myth ian just be carefull not to drill into it Very Happy
Post #92835 Mon Mar 12 2007 8:41pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Just had a call from the dealer. This car is coming in on the 20th March, so I expect to be able to pick up on the 24th.
In addition to all above I have also had Balck and silver badges added all round apart from the steering wheel which I was told cant be done.
You can do a bodge job! Just get one of the wheel centre caps, remove the 'LR' logo. Then drill a small hole in the logo on the steering wheel, put a screw in and just some pliers to lever off the badge. After the badge is removed get the black badge, but some double sided sticky pads on the back and put in place.
Yep, as aljo says, be careful with the steering wheel airbag enclosure Ian. However, I did mine the same method as VA and had no problems whatsoever, done in 5 minutes. Small drilled pilot hole penetrates the green tin badge really quickly so dont press too hard! Self-tapper grips the old badge, pull firmly with pliers, badge will ease out slowly. Double-sided sticky pads (or glue) fixes the new badge on the centre space. Easy-peasy! Good Luck! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #92857 Mon Mar 12 2007 9:37pm
