![]() | Home > Technical > Transmission F mode |
I have had 2 or 3 of these faults all cured by the above mentioned process of locking, unlocking etc. 2005 Zambezi TDV6 - Gone but not forgotten
redtarga Member Since: 16 Oct 2005 Location: Taiwan Posts: 39 ![]() ![]() |
I experienced my first Transmission failed message about 8 days ago. I restarted the engine, and it seemed to go away.
Chamman Member Since: 02 Jan 2006 Location: cruisin Posts: 6 ![]() ![]() ![]() |
After a dealer visit and running diagnostics; turbo modulator faulty so will be replaced. The RRS computer first found fault with engine power (reduced turbo power I assume) so put transmission into F mode to protect the engine. If you stop the engine and take the key out of the ignition - it is the equivelent of a windows reboot. Everything carries on as normal until an error is detected again. I am not a mechanic or software engineer. |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 ![]() ![]() |
The 'F' mode can also be triggered by faulty wiring loom connector at back of gearbox...your LR dealer should know this but it's a pain to check and replace |
