Home > Technical > Cruise Control Issue |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
Hi Smudge,
Wed Feb 28 2007 10:57am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Have you tried it again since 'rebooting' the car ... ? |
Wed Feb 28 2007 10:58am |
smudge Member Since: 12 Aug 2005 Location: East Horsley Posts: 83 |
Yep - will try "rebooting" the car to see if the software has sorted itself out...on way home tonight Range Rover Sport TdV6HSE Bonatti Grey 20" FE Stormer wheels, Privacy Glass, Mats, Boot Mat, black badges, SC grille and vents |
Wed Feb 28 2007 11:05am |
Would expect that to 'sort' it but interested to hear what happens... |
Wed Feb 28 2007 11:43am |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Five bucks that your cruise is now working fine and probably won't act up again for a long time. Happens to me also every blue moon (perhaps once every 3/4 months, and I use cc pretty much every day), the dealer is unable to find a fault message recorded, therefore unable to reproduce and fix, so I have learned to live with it.
Wed Feb 28 2007 12:13pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Mine has cut-out twice on me now. Working fine then will not resume after touching the brake. Works fine after a "reboot". Just one of those things... |
Wed Feb 28 2007 1:18pm |
This happened a couple of times on mine actually...didn't do anything about it and it went away. Same old same old
Wed Feb 28 2007 2:00pm |
KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120 |
happened to me last year. If you pull over, restart it works again until you touch the decellerate button. The dealer/service took it in, said there was a problem with the button contacts and fixed it. I've had it back in again for steering wheel button issues again, this time also radio/cd in addition to crusie control. They fixed it again, claim it was again bad contact. RRS TDV6 (gone)
Wed Feb 28 2007 5:07pm |
ok - tried it on the way home as umbertob said - restarting car sorted it out initially.
Wed Feb 28 2007 5:49pm |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
Sounds like your clock spring ("rotary coupler" in LR speak) needs replacing - not uncommon in 'early builds', although I'm sure LRCS would deny that anyone had suffered the problem.
Wed Feb 28 2007 8:33pm |
nigelkippax Member Since: 29 Jul 2006 Location: Glasgow Posts: 19 |
Before my RRS HSE, I had a Golf Mk6 TD. The same thing happened to me with it, and, after speaking to VW service, it was put down to low fuel. It seem the car knows it was low on diesel, and at a certain level you had to run the car "manually". As if to keep your attention on the instruments more, and hence see your feul was running low. Might be the same thing. WHO KNOWS!!! Hope this helps. |
Wed Feb 28 2007 8:37pm |
Instead of doing a sudoku at the wheel when you have cruise enabled?
Thu Mar 01 2007 11:50am |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
Sounds like any windows based PC to me Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Thu Mar 08 2007 11:01am |
