![]() | Home > Technical > just fitted roof rack, will thule ski box bloack GPS ? |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
At least...here in the U.S. the Land Rover cargo box has to be positioned so that it covers no more than 50% of the fin...otherwise the satellite radio signal does cut out quite often, but it doesn't affect the GPS Satellite signal...
welsh alex Member Since: 15 Oct 2006 Location: england Posts: 17 ![]() ![]() ![]() |
thanks PJPR01
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
Plastic roof box shouldn't block the GPS signals - what you put in the box might though if metallic - even so the fin should only be masked to overhead satellites, those closer to the horizon would still be OK and you would probably still get enough for a fix. Cheers
Since I've had my expo rack on the quality of the phone calls has deteriorated. 2005 Zambezi TDV6 - Gone but not forgotten
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Do you use the phone cradle VA? Or do you connect to the car via bluetooth? Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Cradle. Now tell me the phone cradle fitting doesn't use the fin! |
I wouldn't dream of telling you something like that VA.
bkehoe Member Since: 26 Feb 2006 Location: Wexford Posts: 35 ![]() ![]() |
The GPS antenna is in the rear upper stop light housing, so you've got a few more inches to spare. The fin is used for the PTI cradle and satellite radio services. |
