![]() | Home > Technical > Driving to work - interesting PDC 'fault'... |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Driving in today I noted that when at rest in traffic - and attempting to clear screens (front and rear) with frozen water - i.e. motor driving no water spraying - each time you press the switch PDC would beep - anyone else getting this?
Might be the water from the headlight washers getting on the front PDC sensors? |
It was happening on the rear too, and no water was coming out either - I need to try it when nozzles are defrosted and water jetting to see if fault occurs then.
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Anything and everything sets of PDC at rest.
