Home > Technical > ACC/Front Winch Compatibility
Page 1 of 3 123>
TJ101
Evening All,,
Wondering if what I have been told is correct ??
The G4 when into the dealers yesterday for a couple of things, noisy Vicious fan & knock on the r/h front suspension (ball joint ? !!! ), Both of which are on to be sorted
Whilst there, ask them to look at the active cruise/front park sensors, as both not working, only to be told, that since a front winch is fitted, they have to disable the cruise !!
Has anyone seen the G4 accessories brochure ?, does it say, if you have a front winch, you can not have cruise ? anyone heard of this before ?? 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
www.wessex4x4response.org.uk
http://forum.innovate4x4.com
G4 RRS Gone
Post #78168 Fri Jan 26 2007 7:02pm
TJ101 - I think they might be telling the truth. I can see why it would disrupt the ACC in the same way that the bush bars do. 2005 Zambezi TDV6 - Gone but not forgotten
Post #78169 Fri Jan 26 2007 7:07pm
TJ101
Hi VA, Yep found that post, so why then,when LR Fitted out the G4,S did they put the ACC system on, and not the standard Cruise ?? Crying or Very sad 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
G4 RRS Gone
Post #78174 Fri Jan 26 2007 8:00pm
No idea - maybe they were too lazy to chance the ECU! 2005 Zambezi TDV6 - Gone but not forgotten
Post #78177 Fri Jan 26 2007 8:03pm
Anyway I think the Adaptive CC is fun for the first 1000 miles but I know a few owners have got p***ed off with the thing - too sensitive especially when you pass large coaches = sudden loss of speed. 2005 Zambezi TDV6 - Gone but not forgotten
Post #78178 Fri Jan 26 2007 8:05pm
Pelyma
Im pretty sure TFC has front sensors with the winch, if memory serves me correctly it knocks 2 sensors out but not all. TJ101 are you someone else on LROI forum?
Post #78179 Fri Jan 26 2007 8:15pm
The sensors arn't the problem, you're right 2 should work if programmed correctly. The ACC is the problem. 2005 Zambezi TDV6 - Gone but not forgotten
Post #78180 Fri Jan 26 2007 8:17pm
TJ101
Not bothered with the ACC system !!, but cruise would be handy, with a trip to the prynees coming up ! 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
G4 RRS Gone
Post #78183 Fri Jan 26 2007 8:20pm
TJ101
TCF ?? another member ? The dealer is telling me, the winch is in the place of the sensors ?? so whats behind the box on the lh side ??
Have asked the dealer to speak to Special vehicles, also got customer relations to speak to the dealer as no one seams to be talking to each other
Pelyma,, no, not i, not on LRO much,, LR4X4, is better for me Smile 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
G4 RRS Gone
Post #78184 Fri Jan 26 2007 8:26pm
Martin
Site Administrator & Owner
Pelyma - you're confusing PDC with ACC - the ACC (adaptive cruise control) uses a radar unit in the lower front grille opening of the RRS which is probably blocked by the winch fitment Sad Like this site? Buy some RRSPORT goodies to show your support!
Post #78185 Fri Jan 26 2007 8:29pm
TJ101
Correct Martin, the sensor is to the r/h side of the winch,as you look at it,
must be about 3 inch to the right, so can not see how it impeeds the view ??, but the winch does protude futher by about a inch or so !! 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
G4 RRS Gone
Post #78186 Fri Jan 26 2007 8:37pm
Martin
The radar probably has a wide angle sensor, and would pick up radar reflections straight off the winch. The ACC would probably think that you're a couple of inches from the car infront Wink
You might be able to move the ACC 'box' forward clear of the bumper? Like this site? Buy some RRSPORT goodies to show your support!
Post #78187 Fri Jan 26 2007 8:38pm
or relocate it under the bumper somehow! 2005 Zambezi TDV6 - Gone but not forgotten
Post #78188 Fri Jan 26 2007 8:43pm
TJ101
Well. i could as last restort,,
The way i see it,, If landrover market and sell a front winch to fit your RRS,
or you bought a vehicle (from landrover) you would expect it to work !!
i could maybe understand, if a 3rd party fitted any type of winch !!
At the monment, the ACC, Front park control & front winch are disarmed !!
Also somewhere, there must be a master switch for the cellanoid which is retro fitted, down behide the battery !! 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
G4 RRS Gone
Post #78190 Fri Jan 26 2007 8:52pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
If that doesn't work, could they just take out the ACC module and restore the
"regular" cruise control functions in your car? I imagine it would just be a matter of uploading some software patch - and you would end up with a useless button or two in the cabin, but it's still better than no CC at all. If I didn't have cruise every time I drive to Vegas from Los Angeles, I'd probably rent a car. Wink
I was also told that winches cannot be fitted on Supercharged models, regardless of whether ACC is present or not, since they interfere with airflow to the intercooler down there.
Post #78194 Fri Jan 26 2007 9:00pm
Page 1 of 3 123>
