TJ101
bkehoe wrote:So TJ do you have the sensor box to the left at all? I was looking at a G4 RRS last week and the sensor box was definatly mounted at the front left, slightly higher than the winch. I reckon the numberplate would be the main thing confusing it, had you got all the bits it might have been worth a try getting the dealer to enable cruise and relocate the numberplate to see if it works.
As for your PDC, if you wrap the 2 inner sensors in self amalgamating tape, it should disable them (well, fools the system) and leave the outer two working if the dealer enables front PDC. At least this is what I've been told anyway, will find out soon when I put a winch on my D3!
Hi bkehoe, All the G4,would seam to have the plastic cover(sensor box) to the l/hand side, but there is nothing behind, and told the main module/radar should be sat in the middle, right behind where the winch is now fitted, When they were assembled, none of the main components were fitted, and to reinstate the cruise, cost would be in the region of £ 1500 for the bits + labour / vat etc, same goes for the front PDC
Landrover do not want to know, about sorting this out, even though i am sure, the standard non-active cruise could be fitted
Open to any ideas etc, of how i can pursue further, as not happy, I have what is essentially a RRS HSE without any cruise 997 TT, RR TDV8 Vog SE 90 V8 Hybrid
www.wessex4x4response.org.uk
http://forum.innovate4x4.com
G4 RRS Gone
Sat Feb 17 2007 8:34pm |
