Home > General > OBDII Port
Zipperman19
United States 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
OBDII Port
Hey guys I've had a Check Engine light come on a while ago. I goes on and off ocassionally. Well I went to the store to pick up OBDII reader because the nearest dealer is 200 miles away, and I don't want to even bother with that. Does anyone have any experience using one on the RRS? I read the instructions and inserted the connector into the port when the ignition was off then turned the key to the "on" position and waited, but it keeps having a communication error. I tried the reader out on a different car so I know it works.
Does anyone know if there are special instructions for using a generic ODBII reader on the RRS?
Thanks,
Zipperman19
And no it's not a gas cap problem, its been on and off for a few thousand miles.
Post #75791 Wed Jan 17 2007 2:52am
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
OBDII ports on the RRS use mainly canBus fault reading...you may have an OBD reader that only uses 'K' Line (and older format) so check with your supplier :-0)
Post #75797 Wed Jan 17 2007 9:05am
Zipperman19
Thanks LRtuning, I'll go back to the store tomorrow and see if I can find the right one.
Post #75799 Wed Jan 17 2007 9:12am
LRtuning
The best product is 'CarChip' made by www.davisnet.com in the US
Good luck Smile
Post #75800 Wed Jan 17 2007 9:18am
