Home > Technical > Steering Vibration |
...or an SC!
Mon Aug 21 2006 7:55pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
I just posted a TSB recently released by LR North America - addressing steering wheel vibrations - on a different thread (scroll down to third message):
Fri Sep 29 2006 6:05am |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 |
Paul, you have PM RRS TDV6 Bluetooth, VR, Roof |
Wed Jan 17 2007 1:28am |
Two quite separate Steering Vibrations in the RRS; 1) One is the wheel shimmy that is like out of balance wheels. The TSB that Umberto mention addresses this problem. 2) The other is as PaulB previously mentioned, a driveline vibration that can be felt through the steering wheel. Basically feels like harmonic whirring through the steering wheel on gear changes and when engine is under load (at least on mine anyway). There is no current TSB on this and LR are investigating on a case by case basis. My car has been in for 45 days now getting this problem sorted. Oh and yes, my car has 1) as well RRS TDV6 Bluetooth, VR, Roof |
Wed Jan 17 2007 5:54am |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 |
Hi there
Wed Feb 21 2007 11:03am |
Welcome Nige! You poor ! Don't hold your breath waiting for the answer to come to you. I had the same thing and they ended up replacing torque convertor, hubs, prop shafts, front diff and finally transmission after six months of complaining. It is heaps better now and I hope it stays that way!! I think the front diff replacement had the biggest impact on the steering vibration feedback. Mechanic told me that there was probably a bit of misalingment which flogged out the spider bearing or something along those lines. Don't give up, it is NOT a characteristic!! RRS TDV6 Bluetooth, VR, Roof |
Wed Feb 21 2007 11:31am |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 |
Trinity losened all the engine & gearbox mounts and drove it up and down the road a few times to allow the lump to settle down to a correct alignment. Everything was then tightened up again.
Wed Feb 21 2007 12:04pm |
Thanks Lateral5
Wed Feb 21 2007 2:25pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
Welcome Nutty shouldnt worry to much about it, it may settle down after a few more miles, either that or the other rattles may drown it out what model do you have and post some pics some of my Previous cars -------------------------------- P38 Range Rover Autobiography RRS 2.7 HSE Silver RRS TDV8 HSE silver FFRR Vogue black Disco3 HSE silver RRS 2.7 HSE silver RRS 3.0 HSE BALTI BLUE ______________________________ current vehicles RRS 3.0 L494 Autobiography Audi R8 V10 Spyder AC Cobra Landrover Defender 90 Landrover Defender 110 Suzuki Jimney |
Wed Feb 21 2007 8:08pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Paul, I get a "thump" on the floor going over bumps and thought it might be the exhaust. As you've got the same other problems as me, tailgate rattle and wipers, I wonder if my problem is the same. Please keep us updated. Good Luck! |
Wed Feb 21 2007 8:20pm |
Will do Brian |
Wed Feb 21 2007 9:00pm |
Thanks Paul! |
Wed Feb 21 2007 9:09pm |
That's how mine started, just a slight whirring vibration in my left hand through the steering wheel....ended up as a WHOA, WHOA, WHOA at about 10,000km. At least you know you're not alone! RRS TDV6 Bluetooth, VR, Roof |
Thu Feb 22 2007 7:31am |
Yes ENVOY you might be right.
Thu Feb 22 2007 8:39am |
