![]() | Home > Technical > Steering Vibration |
...or an SC! |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
I just posted a TSB recently released by LR North America - addressing steering wheel vibrations - on a different thread (scroll down to third message):
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Paul, you have PM RRS TDV6 Bluetooth, VR, Roof ![]() |
Two quite separate Steering Vibrations in the RRS; 1) One is the wheel shimmy that is like out of balance wheels. The TSB that Umberto mention addresses this problem. 2) The other is as PaulB previously mentioned, a driveline vibration that can be felt through the steering wheel. Basically feels like harmonic whirring through the steering wheel on gear changes and when engine is under load (at least on mine anyway). There is no current TSB on this and LR are investigating on a case by case basis. My car has been in for 45 days now getting this problem sorted. Oh and yes, my car has 1) as well ![]() ![]() |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Hi there
Welcome Nige! You poor ![]() Don't give up, it is NOT a characteristic!! RRS TDV6 Bluetooth, VR, Roof ![]() |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
Trinity losened all the engine & gearbox mounts and drove it up and down the road a few times to allow the lump to settle down to a correct alignment. Everything was then tightened up again.
Thanks Lateral5
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
Welcome Nutty shouldnt worry to much about it, it may settle down after a few more miles, either that or the other rattles may drown it out ![]() -------------------------------- P38 Range Rover Autobiography RRS 2.7 HSE Silver RRS TDV8 HSE silver FFRR Vogue black Disco3 HSE silver RRS 2.7 HSE silver RRS 3.0 HSE BALTI BLUE ______________________________ current vehicles RRS 3.0 L494 Autobiography Audi R8 V10 Spyder AC Cobra Landrover Defender 90 Landrover Defender 110 Suzuki Jimney |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Paul, I get a "thump" on the floor going over bumps and thought it might be the exhaust. As you've got the same other problems as me, tailgate rattle and wipers, I wonder if my problem is the same. Please keep us updated. Good Luck! ![]() |
Will do Brian |
Thanks Paul! ![]() |
That's how mine started, just a slight whirring vibration in my left hand through the steering wheel....ended up as a WHOA, WHOA, WHOA at about 10,000km. At least you know you're not alone! RRS TDV6 Bluetooth, VR, Roof ![]() |
Yes ENVOY you might be right.
