Home > Technical > Will Brembos fit on a standard HSE discs
llamapoo
Hi i have a Range rover HSE but i dont have the Brembo calipers.
i do have the RRSC 20" wheels though.
my question is: Will the Brembos fit around the standard discs ok or do i need a bigger disc upgrade too.
i dont really wanna change the disc size.
Regards
Matt C
Post #68575 Thu Nov 30 2006 2:52pm
From what I remember it's a straight swap of the calipers. Paul has done it. 2005 Zambezi TDV6 - Gone but not forgotten
Post #68576 Thu Nov 30 2006 3:16pm
Yes, I seem to remember that's the case... it's the wheel size that would scupper you if you had smaller wheels than the 19s.
Post #68577 Thu Nov 30 2006 3:23pm
MAW
Hope this isn't a daft question but does / did the RRS come with wheels smaller than 19's?
Post #68582 Thu Nov 30 2006 4:24pm
The MY06 SEs and below Very Happy
Post #68583 Thu Nov 30 2006 4:29pm
MAW
Much appreciated !! Wink
Post #68585 Thu Nov 30 2006 4:52pm
PaulB
You can't fit the Brembo calipers to the standard disks.
You need to change both items. You will also need new backplates to match the larger discs. Fortunately, these are pretty cheap (I can't remember precisely how much). The only other thing is new brake pad warning light wires. I recal they are bonded into the standard brake pads, whereas they are seperate wires that plug into the Brembo pads.
Once you have all the correct bits, it is a straight forward swap over. They even use the same caliper bolts. The only hassle is bleeding the new calipers.
The good news is that the Brembos are fantastic and it will out brake many much smaller and lighter cars.
Paul
Post #69179 Tue Dec 05 2006 6:55pm
