Home > Maintenance & Modifications > Apple Carplay installation into 2013 L320 SDV6 HSE
Page 3 of 3 <123
T
England 2012 Range Rover Sport SDV6 HSE Santorini Black
Thanks guys.
Yes, I get the odd audio hole, but as the phone's data signal is pretty crap here on the island, I've put it down to that. It only lasts a few seconds and if I end up parked in a hole, I change to on board music as opposed to Amazon Music. I don't think it's any worse than the other unit was . . .
Post #646485 Fri Jan 24 2025 6:06pm
T
Oops! I accidentally just ordered this. I was going to wait, but my finger slipped. Whistle
https://www.aliexpress.com/item/1005008280...180282878w
Post #646570 Tue Jan 28 2025 4:44pm
Golan
United Kingdom 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Accidentally!!! Rolling with laughter
That'll make a massive difference. Nice upgrade, I did look at that for mine...
Still at least you already know how it all comes apart... Should have it fitted within the hour Wink
Post #646572 Tue Jan 28 2025 5:16pm
T
I don't know about an hour. From the videos I've seen it'll probably take a full day. Big Cry
I had some discount points to use up and they offered an extra £30.00 discount too, so it only came in at a little over £150.00. I figured at that price, it was worth a go.
The CD/DVD unit doesn't work on mine anyway, so I'll see if I can fix that when it's out and if I can, it will go in the 'original parts box' in case I ever need to reverse any of this at a later date. I've not used discs for years anyway . . .
Post #646573 Tue Jan 28 2025 5:21pm
T
Just in case anyone's waiting to see how I get on with this, I've just cancelled it.
I've been waiting for a shipping update, but nothing was forthcoming. A quick check showed that the seller was not going to ship for another three weeks.
Needless to say, I told them to forget it and got a refund. Censored
Post #646609 Fri Jan 31 2025 12:12pm
mac27040
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
good job you cancelled it as it the wrong model even though they say its for 2011 onwards, that model is for the newer sports.
you need one like this and check which system you have.
https://www.aliexpress.com/item/1005006236...ry_from%3A
Post #646678 Tue Feb 04 2025 11:19am
T
Thanks, but I'd ordered the right one. I don't know why that link showed the different model? Rolling Eyes
Post #646679 Tue Feb 04 2025 11:26am
rk7
Cpt Jack Sparrow wrote:
Ok, Sound issue resolved, user error Laughing Laughing
I forgot I had a memory stick in the USB port in the centre armrest.
popped it out and low and behold sound from Car play. Thumbs Up Thumbs Up
So Happy Days, fully working.
As is are all of the steering wheel controls, volume and skip track...
Any questions please ask....
CJS
Hey CJS,
Can you please confirm if you're pushing your audio through BT or AUX via CarPlay to have your steering controls work as expected? And is the audio quality any poor than before?
And finally does you reverse camera kick in automatically or do you have to manually select it when reversing?
I am reading so many conflicting posts about these systems so trying to ascertain certain things before I pull the trigger and spend time installing it.
Thank you,
RK
Post #647653 Fri Apr 11 2025 2:31pm
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Hi RK
I'm using blue tooth to the unit, not the Aux jack port, however the factory head unit need to be set to aux to get phone sound.
Downside to that is you lose radio when using phone or Waze for example. I stream radio and use RAYO app so all good for me.
I actually find the streamed radio quality better than the standard DAB.
Hope that helps
CJS
Post #647656 Fri Apr 11 2025 8:47pm
Cpt Jack Sparrow
double post
Post #647657 Fri Apr 11 2025 8:48pm
rk7
Thank you for confirming.
RK
Post #647658 Fri Apr 11 2025 8:58pm
Page 3 of 3 <123
