![]() | Home > General (L461) > She’s arrived….. but 42km on EV 😬 |
bcp Member Since: 11 Oct 2005 Location: East of Scotland Posts: 67 ![]() |
Ours is in the dealership with a coolant leak |
B McP Member Since: 01 Sep 2023 Location: Aberdeenshire Posts: 31 ![]() ![]() |
I get 50 to 54 miles during the cold weather (around zero degrees) and up to 64 miles in the summer (around 18 to 20 degrees). |
FunkGogh Member Since: 02 Oct 2024 Location: inside MacBook Pro Posts: 11 ![]() ![]() |
depends on the road, the outdoor temperature, the drive style, the weight (how many person in the car) the rims and the tires...42Km is not much IMHO, you can do better! Enjoy your car and let we know!
Rowdie Member Since: 14 Jan 2015 Location: Uk Posts: 188 ![]() ![]() |
You say 9.5 hours charge, which suggests you might be using a normal plug in home charger to a domestic socket (Granny Charger) ? . If this is correct, then the Battery will not be fully charged, and the range you got is probably quite normal. Did the Car fully charge to 100% ?
