Home > General (L461) > She’s arrived….. but 42km on EV 😬
RRS25
Norway
Run a total of 450km and thought I would try tested EV mode….. after 9.5hr charging she thrilled me with all electric trip of 42km before battery drained.
Is this normal ?
Advert which prompted me to part with over 2million Nok ! promised 90km.
A bit disappointed.
Ambient was over 10’C and driven below 80km/hr as car is 1 day old.
Post #647486 Sun Mar 30 2025 5:53pm
bcp
Ours is in the dealership with a coolant leak Sad but when working we've been quite impressed with a winter range of around 70 to 80km. Perhaps just settling in??
Post #647494 Mon Mar 31 2025 3:33pm
B McP
Scotland
I get 50 to 54 miles during the cold weather (around zero degrees) and up to 64 miles in the summer (around 18 to 20 degrees).
Post #647495 Mon Mar 31 2025 6:37pm
FunkGogh
Italy
depends on the road, the outdoor temperature, the drive style, the weight (how many person in the car) the rims and the tires...42Km is not much IMHO, you can do better! Enjoy your car and let we know!
By the way...p460 or p550?
Post #647496 Mon Mar 31 2025 7:21pm
Rowdie
You say 9.5 hours charge, which suggests you might be using a normal plug in home charger to a domestic socket (Granny Charger) ? . If this is correct, then the Battery will not be fully charged, and the range you got is probably quite normal. Did the Car fully charge to 100% ?
For this type of charge this is about 2.3KWH * 9.5hrs is approx 22KWH, so only about 2/3 charged. The range if you were driving it carefully (as you say you were) would have been more than this if the car was fully charge. I get about 80 km with a heavy right foot at that sort of ambient temperature, but obviously with 100% charge at start
Its a great car. Enjoy
Post #647498 Mon Mar 31 2025 8:48pm
